| General Scanning Discussion For general questions not specific to a model of scanner or general discussion of use of a scanner. Location specific posts should be directed to the regional forums listed below. |
10-15-2012, 7:30 PM
How many Scanners do you have(or want)?
I'm relatively new to the scanner world(and Ham radio) and just wonder how many people have multiple scanners in use? and if you can (or could)afford more than one, in what configuration do you use them?
I realize everyone has a different need because of their geographical location... just curios if others use multiple units.
I now have 4 units at my listening desk:
Uniden BCD996XT - monitoring county 800mhz Motorola digital/analog system
Uniden BCT15X - monitoring conventional county police - analog only -(approx 15 communities)
RS Pro197 - monitoring county Fire(analog) and State-wide MARCS system, seconday coverage of neighboring county 800 mhz motorola digital/analog system
Uniden BC370CRS - Weather alert and Air
Am I nuts, or should I get one more to cover 'local Businesses', schools, public transport, amateur radio?
10-15-2012, 7:52 PM
not nuts lol i have 4 scanners my pro197 monitoring or county 800MHz edacs system and bordering countys and my pro106 monitoring the state wide MARCS system and thats my traveling scanner my pro2050 for franklin county 800MHz Motorola system and my bc350a is put at this time dont really use it much any more so i dont think your nuts lol
pro197/pro106/396xt
steve
10-15-2012, 8:01 PM
5 on my desk with plans to add another 996xt and a icom 75. I also have 2 handhelds as well as a few retired base/handhelds in storage. If I get my HAM ticket as planned I'm afraid I'll need a bigger desk for whatever ham radios I convince myself I need. lol
Getting even a little bit serious about this hobby is addictive. And expensive.
10-15-2012, 8:01 PM
I only have one.
Callsign: N4CYA
MotoTRBO: Motorola XPR 5550
NXDN: Icom F4261DT
Scanner: Uniden BCD996XT
10-15-2012, 8:03 PM
Casual listeners are usually happy with one or two. Those with more specific needs or desires may use many.
While I might be considered extreme (I have 3 mounted in my car, 2 at work, 2 dozen at home and a couple dozen HH's) I use anywhere from 6 to 10 at a time in my home office. Several are actively decoding data, several are set up for fire toneouts and a couple are set to specific services (rail, air, fire...)
10-15-2012, 8:09 PM
Currently have three.. Two RS Pro-164s that I use for my feeds, and a Uniden BC346XT that I use for myself. Usually scanning three local PD agencies and two fire. I want at least one more.
10-15-2012, 8:42 PM
Yep, you're nuts for sure, but you're in good company!
ScanCHS
Extra Class amateur | GROL with radar endorsement
Uniden HOMEPATROL Extreme | BCD996XT | BCD396XT | BCD996T | BCD396T | BC370CRS
10-15-2012, 9:05 PM
Post of the day
That was funny!
Current Scanners;
(2) Uniden - 996XT at home to listen State Police and local Fire/Police on a selective basis. Identically programmed 396XT for hand held and mobile use around the State of Connecticut. Police, Fire, State Police, Aviation, Utilities, DOT, etc.
I'm a Fire Commissioner, so I use the base scanner to record calls while I am at work, away from home.
(1) Realistic PRO-2004, modified in 1989 (oooooo la la!) for cellular reception and 400 channels instead of 300, plus (Drum Roll) Turbo Scan! (I forget the enhanced speed) Used to quickly plug in a frequency for monitoring. Analog only.
At least three crystal controlled scanners no longer relevant, but "in the day", when one of those 4 or 8 channels lit up, it was happenin'! My first scanner was a Bearcat TMR 8 L/H. 1972ish.
Would love to buy another, but I don't want anyone to think I'm nuts. I'll wait for the next generation of technology.
~Doctor Dialtone
BCD996XT, BCD396XT, PRO 2004 Modified, BC2500XLT Modified, Minitor V
This post is worth another 4 RR points towards free trips and other valuable discounts!
Reason: I left out the BC2500XLT, rarely used - also modified as above.
10-15-2012, 9:17 PM
Have a BCT15X doing my feed, have a pro-164 in my Blazer, but want to upgrade to a digital feed scanner and digital handheld and pass these two on to someone else who may need them. Oh, and I forgot to mention, I have a BC210XL that I picked up from Salvation Army. Still works, keypad has no "spring" to the buttons. Anyone want 'em?
10-16-2012, 6:53 AM
Wirelessly posted (Mozilla/4.0 (compatible; MSIE 6.0; Windows CE, BrailleNote))
I have two scanners I use at home, a uniden bct8 and a uniden bct15x. They are programmed almost identically, but I have more freqs in my 15x. I use the bct8 for most of my scanning needs, but go to the more specific arrangement of agencies in the systems and groups of the 15x when something is geing on. Many times I monitor PD with the 8 and fire/ems/aviation/marine with the 15x. I also have a GRE psr500 for mobile opperations.
Do I want more? Heck yeah! If I could have a separate scanner for every channel I monitor I would be in heaven. Unfortunately that will never happen. I'll likely stick with what I have for now as I plan to get a ham license and will subsequently drop all sorts of money there as well.
10-16-2012, 7:16 AM
I currently own 4. Really only use the PSR800 though
GRE PSR800, Radio Shack pro 421, Uniden BCT7, BC72XLT, BC350C and BC700A
10-16-2012, 7:46 AM
i would love to have them i sent ya a message thanks
10-16-2012, 7:59 AM
You can never have too many scanners ;-)
PSR600/PSR500/PRO106x2/PRO197x3/PRO2096/BCD996T/BC796D
BCT15X/BC898T/HP-1/BC210XLT/PRO-136/BC370CRS
Feeds: Your Account
10-16-2012, 8:16 AM
I have 3. A 796D in my truck along with a Radio Shack Pro 97 for when I am out. I also have a BC 350A hosting a feed here.
I would like to replace 350A with a newer scanner with Alpha tags and get a newer didgital Handheld. I am waiting on replacing the feed scanner because I am hoping that a scanner comes out (I know, here comes the wishful thinging) that can decode Nextgen for railrailroads, as that is what the feed is.
Kevin Fitzsimmons
Uniden BC355 in the truck, a BC350A hosting a feed and a BC125AT playing several rolls.
10-16-2012, 9:07 AM
2 here!
Fixing to get a third though...
10-16-2012, 10:29 AM
Right now there are 9 scanners on
1 796D Federal and Military
1 996XT Federal
1 396XT sitting on one active Federal channel
1 996T Police
1 780XLT State Trunk system
1 780 XLT Fire
1 PRO 2035 Local FD
1 PRO 2050 Local PD
1 Yaesu FRG 100 USCG HF
4 Various types of antennas on the roof and a Stridsburg M204M four port multi coupler
Kenny
10-16-2012, 1:54 PM
Hi mainintrest for meismonitoringhf aero,vhf airbands i also share a shack at dads place with 50 receivers,The list in the bottom is what i use in my shack,can never have too many radios..
SHACK CURRENTLY:
ALINCODJ-X11,ALINCODJ-X2000,ALINCO DX-R8 (2)
AOR-8200MK3,AOR-8600MK2
DRAKE-R8B,DRAKE-SW2
GRE-PSR400,GRE-PSR500
GRUNDIG SATELLIT-750
ICOM-PCR1000,ICOM-PCR1500,ICOM-R3,ICOM-R20,ICOM-R71A,ICOM-R75 (2),ICOM-R2500,
ICOM-R7100,ICOM-R8500,ICOM-RX7
KINETIC SBS-3
PALSTAR-R30A
REALISTIC-PRO2035
RFSPACESDR-IQ (2)
SANGEAN-ATS909X
TEN TEC-320D
UNIDEN-BCT15X,UNIDEN-UBC245,UNIDEN-UBC396T,UNIDEN-UBC396XT,UNIDEN-UBC780XLT
YAESU-VR500
ANTENNAS:
AOR-SA7000 WIDEBAND 30KHZ-2GHZ
CENTREFIRE MULTIBAND DIPOLE 25MHZ-500MHZ
ICOM-AH7000 DISCONE 25MHZ-1.3GHZ
POLAR-214A CUSTOM DIPOLE 118MHZ-136MHZ
RADARRAMA ADSB 1090MHZ
RFI-GP3 CUSTOM GROUNDPLANE 118MHZ-136MHZ
SCANNMASTER-SP1300 WIDEBAND 500KHZ-1.5GHZ
WELLBROOK-ALA1530 ACTIVE LOOP
WELLBROOK-ALA1530AL-1 ACTIVE LOOP
WELLBROOK-ALA1530L ACTIVE LOOP
Regards Lino..
10-16-2012, 2:34 PM
I have a few.
16 x BCT15's (Both flavors)
12 x BCD996's (Both flavors)
10 x BCD396's (Both flavors)
8 x BC-RH96 Remote Heads
Also:
20 x PRO-2006's
12 x PRO-2035's (European versions)
8 x PRO-2032's
4 x PRO-2039's
12 x PRO-2041's
2 x ICOM IC-R7000's
About 20 other miscellaneous scanners
I 'want' more.
I'm now waiting for the new Uniden TDMA scanners to come out.
Rich
10-16-2012, 2:38 PM
2 br330t vr500 icomr5 346xt 996xt that should coverit i mite buy a gre 700 to add. how about a 12 step program for scanner addicts lol
10-16-2012, 3:04 PM
TRBO Trawler
1 - BCD996XT
1 - HomePatrol 1E
1 - Pro 2052 discriminator tapped and running with DSD 1.6 for experimentation with digital modes not monitorable by scanners.
I'm content with what I presently have.
