Old 11-05-2012, 6:03 PM
Lightbulb Receiving Antenna vs.Transmitting Antenna
I was wondering how I would check the ohms reading at the coax connection point on a Antenna that I built that I am only using as a Receiving Antenna and not a Transmitting Antenna without a SWR meter? Does the ohms there make a difference?
Old 11-05-2012, 6:09 PM
The instrument used to find the resonant frequency of a receive-only antenna is called a noise bridge. You set it to 50 ohms, for instance, then tune the receiver to a point where the noise changes. Or you set the receiver to your desired channel then adjust the bridge to where the noise changes and then read the impedance from the position of the control on the bridge.
Good noise bridges are precision instruments and are not cheap.
Old 11-06-2012, 1:08 AM
Does resistance make a difference or not? Yes it does, but its' worth pointing out that when it comes to undertaking antenna measurements there is a lot more to "Ohms" than we normally associate with this measurement.
To start with we dealing with an measurement taking almost exclusively on a sinusoidal wave, which will vary constantly depending on the point at which its taken from on the antenna element, and the time its taking at i.e. a reading other than 50 Ohms does not mean an antenna is not resonant ...... and then things get more complicated ........!
To add to what W2NJS has contributed, antenna measurement is a science all on its own, which, to undertake requires a whole bunch of instruments. Noise bridges are great pieces of kit to have (and as W2NJS has said, are precision instruments and not cheap), a simple SWR meter is also great to have, and so are things like vector analyzers to undertake things like S-Parameter tests, and these too are big big buck pieces of hardware but are essential to properly measure and characterise antenna performance
Read the following online article.
Impedance of an Antenna
There are hundreds on-line like it if you type in to Google "antenna impedance"
Old 11-06-2012, 6:31 AM
n4yek's Avatar
Here is an example an antenna analyzer:
MFJ Enterprises Inc.
Here is one on ebay:
http://www.ebay.com/itm/ws/eBayISAPI...m=120685683212
Danny Harp Jr.
HAM Radio Operator: N4YEK
Old 11-06-2012, 12:41 PM
kb2vxa's Avatar
To clarify, ohms DC is one thing but ohms AC is a horse of a different color. Here we get into VAR or volt-ampere reactive or another way of stating it, impedance and with RF we simply call it impedance. When it comes to antennas a noise bridge is not for the average ham or experimenter being rather complicated to operate and interpret the readings while the MFJ analyzer linked to above is easy and comes with instructions for using it for a variety of applications, not just antennas. Pricy yes but not unreasonably so and well worth the investment for those who do a lot of antenna, tuner, delay line, coaxial matching sections and related work. I don't own one not having sufficient need but borrowed one when I needed it and believe me it's a breeze to work with.
Yeah, I'm back safe and sound after the big blow, a little worse for wear but I'm working on it.
