Old 11-11-2012, 7:22 PM
Default Losing frames
i have a tap on my bct 8 on which my local pd and fire is on a provoice system so i monitor with them. from time to time i get good signal. and bad signal like it decodes good and bad at times. Does anyone know a way to stop it from dropping frames so i could hear everything a lot clearer? thanks!
own a pro 404, and a bct 8 with a discriminator tap.
Old 11-11-2012, 11:27 PM
W8RMH's Avatar
I would try to improve your reception, maybe by using an antenna tuned around the 456 MHz range.
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
Columbus Police Citywide Dispatch
Old 11-11-2012, 11:44 PM
Well they are 800 MHz here and I have a 800 MHz antenna :/
Old 11-12-2012, 12:08 AM
W8RMH's Avatar
OK. You didn't post a system and I was looking at the wrong one (LTR). Looks like you have the antenna issue well in hand.
Old 11-12-2012, 10:36 AM
i tried changing some settings in dsd and it did seem to help alot i don't lose as many as I did before, and i hear them alot more clearer. I think that's all it was =P
