Taken straight from the Montreal Database page found here on RR:
http://www.radioreference.com/apps/d...5210#cid-10876
Montreal Police are on a conventional UHF (400 MHz) system
Montreal Fire are on the "Ville de Montreal" Motorola P25 (14F - 201) Trunked system
Montreal FIRE Trunking System, Montreal, Quebec - Scanner Frequencies AND use P25 Simplex frequencies described in this section
Montreal EMS are on the "Reseau Securite Publique RSP - Montreal" EDACS system
RSP Montreal Trunking System, Montreal-Metro, Quebec - Scanner Frequencies
There are some channels on there that are encrypted, which no scanner is able to receive. The scanner you mentioned will work otherwise.
-Shawn
