  #81 (permalink)
Old 02-07-2013, 9:26 PM
Yea, I know, even LSM things you note. I was using the term 'QPSK' broadly to include HPCM....though I know it is not. The point is that things changed for scanners when QPSK was implemented on the control channels over C4FM, and even more from Phase I to Phase 2 with the voice channels going to digital. Simple adaptations with a standard FM discriminator went down the tubes. (Or should I say 'down the semiconductors'.....lol)
From all I can find on HCPM, it is going to be less simulcast overlap tolerant than HDQPSK on the talkout link. This is all implied in the statements be published; I just can't dig up an real info on the HCPM simulcast overlap delay tolerance. Any info would be appreciated on that; I have real world app to solve where I need that.
  #82 (permalink)
Old 02-07-2013, 10:31 PM
xmo xmo is offline
The standards committee says that their future work includes: "Harmonized-Differential 8 Phase Shift Keying (H-D8PSK) modulation for downlink for improved simulcast delay spread" - so that's a subject to start your research.
  #83 (permalink)
Old 02-08-2013, 8:23 AM
Gentlemen, this has truly been a wonderful discussion/thread!! Just spent a few hours catching up since I last checked in and have to say I'm impressed! I have learned a great deal from the posts contained herein and feel at least slightly vindicated in my own beliefs.
Beachmark, rak313, xmo, the rest - folks, I thank you, this is exactly the kind of discussion I think we really need here.
I still maintain a decent self contained (i.e. not tied to a PC, etc.) consumer scanner can be made at reasonable cost, $1K or less, that will significantly outperform what is currently on the market both in the RF/IF performance and functionality and in the post IF processing performance and functionality. But the issue of market value and potential profit given the small size of potential customers remains as an unfortunate stumbling block. I'm pretty sure this is why the two biggies, GRE and Uniden, would be reluctant to really aggressively attack this effort. If anybody is insane/naive enough to do it (the way those of us who really understand the true technical issues would really like it to be done) then I think it might have to be a third party.
I have been dying to see schematics for the current consumer digital scanners since forever but due, I guess, to significant competitive secrecy they are not available, at least easily, though I know some on this site do have schematics available they do not appear to openly share them most likely due to the fear of legal repercussions assuming such information has been deemed confidential company material. The best I have heard is that you can obtain service manuals with schematics for Radio Shack branded scanners which means that should give you the same basic info for GRE scanners (i.e. the Pro106 is essentially identical to the GRE PSR500, etc.). I had thought that RS was no longer providing these service manuals but have read in these forums that they are now available again for a small fee (sorry, I don't remember where I read this - most likely in the Radio Shack Scanner section somewhere). If I were not essentially restricted to my house as I am currently I would attempt to purchase one; not sure if it could be ordered online.
In any case, I have long been of the opinion that the consumer scanners do not use an I/Q demodulator and solely rely on a discriminator approach for demodulation. As has been said, this is adequate for C4FM P25 Phase 1 but insufficient for other than perfect quality DQPSK (or whatever QPSK based mod scheme is being used) Phase 2 or the more currently prolific Phase 1 simulcast systems. I am well aware of the amplitude limiting feature of FM discriminators (what makes them work great for moderate to high level signal noise reduction in analog FM receivers, of course) that becomes a hindrance when dealing with complex modulation systems with needed information contained in the amplitude of the signal. I actually only knew this to be true but wasn't quite up on exactly why given the phase-centric nature of the PSK forms and thank beachmark for his excellent description of why this is the case - I hadn't thought of the transmitted signal filter shaping "modulating" (not sure if that exactly fits but that's kind of how I'm thinking of it) the signal such that amplitude changes result and needed to be correctly accounted for at the receive end. My knowledge mostly ended at the IF though the demod hardware is familiar to me (at least circa the mid 90's of the last century) and I am pretty comfortable with constellation and eye diagrams, etc.
What I found unusual, oddly, was that when I really dived into the hobby scanner knowledge base concerning digital signal demodulation I saw lots of references to discriminator + bit slicer approaches (many years ago) and I actually hadn't worked much with discriminator approaches professionally as we used I/Q demodulators so I thought it odd, at that time, that the discriminator + slicer approach even existed. Of course I understood later that that approach was a natural easy to implement (and cheap) path to early digital signal processing given the FM only scanners of the time and the simpler nature of the signals being demodulated (early trunking control channels and paging signals, etc). Now the slicer has been replaced with a PC sound card and things have advanced significantly; however, we still are relying on what can come out of a FM discriminator. Most seem to think that this is the end-all-be-all and software can do anything we need with just that but I know this to not be the case. I kept wishing that scanners would be made with external buffered true IF taps and that some simple PC IF level (at least 500KHz or so) cheap card would be made available for PC's to interface directly with the receiver's IF output and bypass the discriminator altogether; if the card also had a good hardware I/Q demodulator on board then that would be super. I guess that 455KHz IF downconverter linked to earlier is on the right path here. Still, you are at the mercy of the quality of the receiver's final IF filter and whatever issues it has unless you tap prior to that or use the previous higher frequency IF and provide your own hardware or software filtering. I got a little excited initially when GRE came out with their PSR800 model that included an "IF output" but it turned out to be a bit of false advertising - their "IF Output" is really a discriminator output, still useful for many things but not a true IF tap. Anyway, I was pretty sure that the lack of a true I/Q demodulator limited things somewhat and could be a factor in the later simulcast issues. Unfortunately, I wound up thinking that the equalizer might be a bigger factor but beachmark has, I think, made it pretty clear that that is not where the focus should be - at least given current information.
In one of my earlier queries on these forums (too late and too tired to go looking for it and it was some years back) I inquired about what the professional subscriber rigs used in the demodulator sections and got an interesting reply from someone who claimed to have schematics of a Motorola (I think, if I remember correctly) P25 radio. He did not post those schematics or otherwise send me any copies but he did state that the unit actually used BOTH a FM discriminator and a I/Q demodulator and switched dynamically between them on the fly as needed. As I recall, I think he had some info that said the radio used either demod system as needed to get the best voice decode using some algorithm to measure quality or some such. In perusing the net somewhere around this time, I found some document based on some study or other that analyzed the efficacy of discriminator approaches versus I/Q demodulator approaches given QPSK modulated signals in differing environments. Most of it was over my head, as I recall, but the jist at the end kind of amazed me given how much better I thought I/Q demodulators were than discriminators - apparently, if I understood it correctly, the study concluded that, in some signal quality situations the old discriminator actually was a better choice. After that, assuming that study was accurate and that my understanding of it was essentially correct, putting that info together with the Motorola dual demod approach I figured 1) that the old discriminator had more usefulness for digital signals than I first thought and should not be discarded altogether and 2) that the Motorola approach of using both an I/Q demodulator and a discriminator (assuming that info was accurate) might be common on modern (at the time) digital LMR subscriber units. If so, this might be another factor in the search for reasons why the professional gear handles simulcast issues (and, presumably, P25 Phase 2 signals now) better than consumer grade scanners. I'll have to try and find that old study again - I am sure you folks can better interpret it than myself.
As to the software over hardware debate - certainly the software is vital and has insane power WHEN combined with the right hardware but...relegating the hardware to minor importance is off the mark, I think. As others have said, no amount of super software can completely overcome serious hardware limitations. In this case, it's a bit like saying that if your brain is powerful enough your ears and eyes can be of poor quality and all will still work at 100% efficiency in the visual and aural department. Maybe if we stretch things a tad and invoke special psy powers or weird quantum effects and with a really super cosmic brain buuutt...
Anyway, I have really enjoyed this discussion and have learned a great deal especially, of course, about those areas I am so weak in - pretty much anything outside the RF/IF and analog sections.
Beachmark, maybe you could walk into a Radio Shack and attempt to order a service manual for the Pro-106 and/or Pro-197 scanner - I seem to recall that that discussion brought out that you couldn't order it online and actually had to go to a store and have them order it for you but I'm not sure.
Anywho, great discussion - keep it going! If I were close by I would gladly work with you on that "best scanner in the galaxy" (ummm, kinda stretchin' things a tad, there, aintcha...;-))!
-Mike
  #84 (permalink)
Old 02-08-2013, 9:21 AM
xmo xmo is offline
A schematic of a scanner might prove interesting but as far as a Motorola digital radio is concerned, all of the demodulation is done in custom IC's - so the schematic is mostly big rectangles!
Here is a short quote from the service manual for the Astro Spectra which is Motorola's very first digital radio [along with the Astro Saber] :
ABACUS II IC
Once in the ABACUS II IC (U301), the first IF frequency is amplified and then down converted to 450 kHz, the second IF frequency. At this point, the analog signal is converted into two digital bit streams by a sigma-delta A/D converter. The bit streams are then digitally filtered and mixed down to baseband and filtered again. The differential output data stream is then sent to the VOCON board where it is decoded to produce the recovered audio.
The ABACUS II IC is electronically programmable, and the amount of filtering, which is dependent on the radio channel spacing and signal type, is controlled by the microcomputer. Additional filtering, which used to be provided externally by a conventional ceramic filter, is replaced by internal digital filters in the ABACUS II IC.
The ABACUS II IC contains a feedback AGC circuit to expand the dynamic range of the sigma-delta converter. The differential output data contains the quadrature (I and Q) information in 16-bit words, the AGC information in a 9-bit word, imbedded word sync information and fill bits dependent on sampling speed
  #85 (permalink)
Old 02-08-2013, 4:43 PM
Originally Posted by Mike_G_D View Post
In one of my earlier queries on these forums (too late and too tired to go looking for it and it was some years back) I inquired about what the professional subscriber rigs used in the demodulator sections and got an interesting reply from someone who claimed to have schematics of a Motorola (I think, if I remember correctly) P25 radio. He did not post those schematics or otherwise send me any copies but he did state that the unit actually used BOTH a FM discriminator and a I/Q demodulator and switched dynamically between them on the fly as needed. As I recall, I think he had some info that said the radio used either demod system as needed to get the best voice decode using some algorithm to measure quality or some such. In perusing the net somewhere around this time, I found some document based on some study or other that analyzed the efficacy of discriminator approaches versus I/Q demodulator approaches given QPSK modulated signals in differing environments. Most of it was over my head, as I recall, but the jist at the end kind of amazed me given how much better I thought I/Q demodulators were than discriminators - apparently, if I understood it correctly, the study concluded that, in some signal quality situations the old discriminator actually was a better choice. After that, assuming that study was accurate and that my understanding of it was essentially correct, putting that info together with the Motorola dual demod approach I figured 1) that the old discriminator had more usefulness for digital signals than I first thought and should not be discarded altogether and 2) that the Motorola approach of using both an I/Q demodulator and a discriminator (assuming that info was accurate) might be common on modern (at the time) digital LMR subscriber units. If so, this might be another factor in the search for reasons why the professional gear handles simulcast issues (and, presumably, P25 Phase 2 signals now) better than consumer grade scanners. I'll have to try and find that old study again - I am sure you folks can better interpret it than myself. -Mike
That would be interesting to see, Mike. And one thought; P25 subscriber units needed to work in FM for the voice channels in Phase 1 P25, so having an FM discriminator makes sense. Even in Phase II P25, where both control and voice channels are digital, there is a need for analog for transitioning between phases of deployments. And, I think talkaround is often still analog FM; anyone please jump in on clarifying that.
Naaaah, just tuning up sales pitch for the first brochure....I figure it will actually be the best scanner in the UNIVERSE, but decided to started with just claiming GALAXY level to allow room for the future Marketing VP to be creative.....LOL!
  #86 (permalink)
Old 02-08-2013, 5:15 PM
ABACUS II IC
Yep, you never know 'til you see the schematic 'in the raw' to see what you can decipher from it. And the description of the Moto radio IC is inline with all of the DSP processing that I have been cathcing up on in the the last week, being used for a lot of RF processing like demod and RF filtering like the new DSP DAS repeaters; it has true I-Q signal sampling.
BTW, an IQ demod can be used to demod plain old FM.
I checked out the online parts list for Radio Shack scanner that someone linked earlier in this thread. It has a mysterious 'analog IC' with no PN, but PN's on other IC parts. The processing apprears to the be a video gaming type of high level processor, with a lot of DSP power. However, I noted it that it did NOT have any A/D converter in it. So without seeing even a block schematic and having some inkling of the nature of the mysterious 'analog IC to try to see if there were 2 bits streams into the DSP, I can't get any further.
  #87 (permalink)
Old 02-08-2013, 7:15 PM
Yeah, blasted high level IC's and SOC's! Need to include little window holes and super magnifiers for us curious outsiders;-)!
Something I forgot to mention in my last, overly long - sorry, post was that when I was looking into this way back when and was still focused on I/Q demodulators as the bee's knees the knowledge that they could do the analog FM demod was one thing that kept me from considering, and being surprised by, the continued use of the discriminator in common use in the consumer digital scanner realm. To keep the amplitude noise immunity inherent in FM, external amplitude limiters would need to be employed but then that's the case with a basic discriminator, also, right? I'm trying to recall the internals of the TDMA and FM dual mode cellular system mobiles and portables we worked on and seem to recall that we used only the I/Q demod and, I guess a limiter for the analog FM side. Back then the US cellular system was still pretty centered on only the 800MHz band and had to accommodate both the older AMPS analog 30KHz analog FM as well as the newer digital modes, TDMA and CDMA at the time, so FM transmission and demodulation was mandatory, unlike today's cellular systems. We even had a group that was working hard to develop "digital FM" which, in my limited understanding, attempted to replace standard FM analog transmission circuitry with digital I and Q outputs which "simulated" a real analog FM signal. A lot of time and money went into that effort and it was lead by a really sharp guy but, in the end, it was finally scrubbed since, using the technology available back then at least, they were just unable to make the digital FM system work as reliably and cheaply as just using a simple analog VCO techniques. Now, of course, the DSP and D/A technology has progressed massively since that time (early to mid 90's).
Back to the the demodulator stuff - with current state-of-the-art technology, can you see any advantage to having a basic discriminator on hand, notwithstanding the phantom study document I mentioned earlier, based on your own knowledge? I'm not sure I follow when you stated the need to "...there is a need for analog for transitioning between phases of deployments."
By the way, I think you have a little misunderstanding of the differences between P25 Phase 1 and Phase 2. True pure Phase 1 systems are all digital, control and voice but purely FDMA based. Phase 2 systems are 2 slot TDMA based digital systems which, I think, can also accommodate Phase 1 type FDMA voice channels when needed. Prior to the full implementation (and finalizing of standards, I am assuming) of true phase 1 P25 trunking systems, Motorola used modifications of their analog trunking systems to allow mixed mode trunking systems using P25 CAI (Common Air Interface) digital voice channels as well as regular analog FM voice channels. In many circles, especially the hobbyist realm, these mixed mode systems were often erroneously labeled as "P25". They should be generically termed as "Motorola 3600 baud mixed mode systems using P25 CAI and analog FM voice channels" or thereabouts. Many of these types of systems are in service today and are slowly being transitioned or readied to be transitioned to pure Phase 1 or Phase 2 P25 systems. Where I am, they use a huge mixed mode trunking system of this type: San Diego County - Imperial County Regional Communications System (RCS) Trunking System, Various, California - Scanner Frequencies. As far as I know, the plan is to eventually replace it with a true Phase 1 system but I imagine they are considering Phase 2 as well; they do have some 700MHz phase 1 sites in test and/or limited use mode in the county. The surrounding counties are in similar states of flux.
It should be noted that the above mentioned mixed mode system is a simulcast system and you can hear the simulcast effects on the analog FM voice channels at times when the phase distortion gets nasty. Of course, on the digital voice channels, the speech just goes into R2D2 mode when that happens (this is on my consumer level GRE scanners).
I'm pretty sure that, if we could look deep enough, we would find that the consumer scanners of today still use standard discriminators solely which would account for why they have issues with complex modulations with important amplitude information. This is likely the reason why the firmware updates issued by the relevant manufactures of these devices which try and fix these problems seem to have only limited success - there is only so much post discriminator software magic that can be done - to me it is kind of amazing they have done as well as they have if they really are relying on just a discriminator (or quad detector).
-Mike
  #88 (permalink)
Old 02-08-2013, 10:18 PM
Hey Mike, I am not surprised if I have some misunderstanding of the Phase 1 P25 system and I'd appreciate anything I can learn. I am trying to do about 6 years of technology deployment catch-up in a couple of weeks! So I don't mind being corrected and steered right, and glad you are tolerant enough to read my 'epistles' enough so as to percieve that. All that I read so far made me think that the Phase 1 voice channels are FM; the 800 Wash DC system is this way as I understand it. BUT, heck there is always so much variation in these PS system with all the vendors that anything would not surprise me. So I will take it for fact that you are spot on for now and run with that; thanks!
That begs a question: Do phase 1 P25 voice channels use C4FM on the early ones and then LSM on some later Moto systems? (And this kinda makes sense...I was reading this eve that Harris(M/ACOM), Tait, and others appear to have fought and won vs Moto in the Phase II harmonization work to force 12 kbps and an improved vocoder to be adopted for phase 2 TDMA; I can see that if Moto was trying to make LSM with 9.6 kpbs the Phase 2 standard for voice and control; they would have a big head start. And it truly looked to be inferior versus the final harmonized standard.)
And my comment about the analog hanging around comes from some info I had on some systems that talkaround was still FM, plus the mixed mode stuff you refer to. But again, that is info coming in on a tangent, and I am still trying to synthesize all this into a complete, coherent picture. I would expect mixed mode FM/digital modulation P25 to be hanging around for a looong time; once these systems get deployed, the politcal process of getting the money for go full digital may get waylaid for years and years in any municipality.
As far as IQ demod of FM, all you really care about for demod of FM is the rate of the zero crossings of the IF signal waveform. In thinking of a contstellation diagram, imagine a vector of constant amplitide just spinning backwards and forwards around the constellation in a continously varying fashion rather than passing through specific phase points at specific times. There is no reason that an IQ demod can't pick and process this out: take phase samples and take the differential (I think; as I recall, FM is the differential of PM...or is it the integral??). Limiting the amplitude can be done somewhere to get rid of the AM. (I.e., make that vector a constant amplitude.) But really, as long as the IQ processing can just determine phase, you have all the info you need, with or without a limiter. And (now I am REALLY thinking off the cuff = DANGEROUS), since all you need is the zero crossings of the waveform, I don't think you even need both I and Q, just one or the other.......hmmmm. (Which makes sense as a qudrature detector can only get phase info: it only has one mixer.)
For the first part, no I can't see any obvious reason to keep a discriminator UNLESS is is just easier and cheaper for the actual FM detection process that somehow is hard to do with some of the CHEAP IQ detectors and A/D's etc that a scanner would need to use. A lot of that question depends on the A/D's that follow and what you may have to do make cheap parts work well with various signal types. (AND when you are scanning, it would surely slow scan times to have to scan a bad with one detector, and then go back and scan it again with another. So one detector is better for that.)
With the state of the art stuff, I KNOW you can detect all of the present modulation types (FM, CMDA, GSM, TDMA, and so forth, even with them all mixed together at the same time) with no problems; we design mixed mode repeater systems with modern DSP filtered repeaters all day long that can do that. But that technology might be expensive for a scanner. After seeing that video procesing chip in the RS scanner parts list as I mentioned earlier (probably from the TV or computer industry), then all the thoughts expressed here by others that the scanner parts are CHEAP really hit home.
Ultimately, your question is one that if I were back in the labs, I would want to sit back for a few days and roll around in the ole brain cells. So anything I say has some qualification. (Hey, I'm an engineer....what else would you expect?? LOL!)
And yes, at the risk of being repititious, the PRIME SUSPECT on my list for scanner performance is the detection circuit. As said, a discriminator can do something with C4FM, but when DQPSK came along, that game changed. That's my best educated guess for now.
  #89 (permalink)
Old 02-08-2013, 10:28 PM
I dunno.....you might not like what you see....if all those theories of little men running around inside them are true!!
  #90 (permalink)
Old 02-10-2013, 12:46 AM
Well, ...where to start! Firstly, given the posts on this thread by you and several others, I rather think I am the one who will be "corrected and steered right" the most frequently! But if I have an occasional nugget of info to contribute that is needed, relevant and accurate I'm happy!
Pure P25 Phase 1 systems should never have any analog FM voice channels as far as I know. If the systems are labeled as "P25 Phase 1" then they should be P25 FDMA CAI voice channels with a 9600 baud control channel, period. Having said that, C4FM is, technically, just FM modulated by four digital dibit symbols represented by four fixed FM deviations. So, from a technical standpoint, it is "just FM". I recall many years ago where a coworker mentioned to me about a friend of his that worked on the then new digital LMR gear who kept saying that it was "just FM"! I'm sure he was referring to the C4FM modulation used. It made sense to use C4FM as it was the easiest to implement and deal with in terms of using the well understood FM-friendly design techniques for both subscriber gear and infrastructure. It's a nice clean constant envelope modulation that behaves well under the conditions we're used to that work well with analog FM. Just like analog FM you don't need linear PA's, friendly and familiar, from a FM LMR standpoint, (and efficient) class C's work just peachy so no problem there. From a transmitter designer's standpoint, it's almost a walk in the park to dip the toe into the digital modulation waters using C4FM. And, as we have discussed, in the receiver side of things, using common FM demodulator techniques works fine too (so long as we're avoiding things like LSM, of course). Also, according to the literature, C4FM can be relatively easily accommodated alongside CQPSK which, as I understand it, was the early on determined upgrade path to the future Phase 2 two slot TDMA format. I'm a little unclear on that as my experience with QPSK was with the pi/4DQPSK TDMA US DAMPS cellular system and it needed a linear transmitter and an I/Q demodulator in the receiver. I'm thinking that either the lesser complex form of CQPSK uses a form of shaping filter that does not "modulate the amplitude" so much that you need to recover that at the receiver end OR that they were just talking about the fact that a CQPSK receiver could easily handle a C4FM transmission - which is true, of course, and makes more sense - so they were talking only about newer gear HEARING the older only and not the other way around. This, too, might bring us to the next subject.
As far as I know, LSM (in P25 Phase 1 simulcast trunking systems) uses CQPSK modulation but only in the outbound path from the control site. So, if you use that for pure FDMA Phase 1 systems, then the subscriber units do not need to make their transmitters fully linear in the PA's - old cheap standard Class C's are still acceptable. Their receivers do need I/Q demodulators but that should not impact the unit's total power consumption near as much as adding a less efficient linear or even linearized PA to the transmitter. So you get a "half and half" scenario. When we move to full Phase II systems, however, you will, as far as I know, need to have CQPSK coming from the transmitter of the subscriber units as well which means that they will need linear or linearized PA's too. But, in the last 20 years, relatively efficient linearized PA's with sufficient linearity to handle the complex modulations now used in the LMR and Cellular markets has come a very long way - it was a big problem for us back in the early 90's but I don't think that is the case anymore. I don't know if the new highly efficient linear/linearized PA designs come down to a Class C's power draw level and up to a Class C's total efficiency but I believe they are far closer now then they used to be, 15-20 years ago. Apparently, it's close enough, though, so that, given the improvements in other areas of the transceiver's design, the total power draw still comes within acceptable levels for a LMR portable unit - and then, too, battery technology has also improved. Anyway, that means that the Phase 1 simulcast (LSM) systems probably use LSM for the outbound (control to subscriber) control channels and for the voice channels (site to subscriber) using CQPSK modulation (or some variation thereof) but receive the Phase 1 subscriber units using standard C4FM modulation. This really makes sense as the subscribers certainly wouldn't "simulcast" from multiple transmitters (we're not talking 802.11n advanced MIMO techniques here, just yet). In Phase 2 systems, however, all Phase 2 TDMA users, subscribers and control sites, will use CQPSK (or whatever variation it is) and Phase 1 subscribers can still be easily accommodated within the same system as long as their receivers can easily handle CQPSK - which the newer ones obviously do. Another way to put it might be - if you can effectively handle CQPSK you can effectively handle LSM and, of course, C4FM. You can kinda see the logic of the upgrade path here:
1) First, implementing mixed mode analog FM trunking combining digital C4FM and analog FM subscribers together using standard Class C PA's and standard receiver FM demodulators.
2) Second, adding effective simulcast technology using LSM when subscriber units have all moved up to using fully I/Q demodulator based receivers which they need to do anyway for future upgrading to TDMA Phase 2 CQPSK systems (albeit in FDMA mode unless the transmitter PA is upgraded also).
3) Third, phasing out all analog FM only subscribers and subsequent implementation of pure digital P25 Phase 1 FDMA systems using receiver I/Q demodulators in subscriber units thereby allowing LSM when needed as well as a path to Phase 2 inclusion as above.
4) Fourth, implementation of full P25 Phase 2 TDMA systems with a mixed subscriber base of TDMA and FDMA units (when done as an upgrade from an older Phase 1 system) all using receiver I/Q demodulators and all or most subscriber units using linearized CQPSK capable PA's (newest units having TDMA capability while older units lacking such PA's will either be slowly phased out or upgraded in hardware when possible).
5) Finally, phasing out all FDMA only Phase 1 subscribers and subsequent implementation of pure CQPSK 2 slot TDMA Phase 2 systems with Phase 1 and analog FM capability in subscribers retained for direct off network simplex and mutual aid use when needed. LSM implemented as needed - all hardware easily supports it.
The above is simplified and is my best guess only. Also, there is much left out that I am aware of (as I said - to keep it simple). One thing that should be pointed out is that there were many different "half-way paths" in and between the steps noted above. As the standards were awaiting finalization, manufacturers, especially Motorola, made partial steps using proprietary technology that was supposed to be upgradeable to the final standard when it was finalized. They did this with their proprietary Astro C4FM modulation prior to P25 Phase 1 FDMA C4FM digital voice modulation finalization and again with their X2 TDMA systems while awaiting Phase 2 finalization. As I indicated before, the 3600 baud Control Channel Motorola mixed mode analog FM plus digital P25 Phase 1 CAI subscribers systems are proprietary systems in preparation for full P25 Phase 1 as well, providing an upgrade path for large systems already in place and having many analog FM subscribers. Hence, you can see why there is much confusion among hobbyists and even many in the industry. Such confusion can be summed up in what I call "Total Hooey Distortion" which is a result of the following: what I call "Specialization Isolation Distortion (or "Specialization Isolation Disease" or Specialization Isolation Distortion Disease" take your pick)" mixed with "Acronym Overload" mixed with what I call "Gotta Know It Now, Error Correct Later Syndrome" and finally, mixed with an all too hardy dose of "Massive Marketspeak Mangling" (aka, the infamous, "M Cubed Factor"). And you know all that mixing is a nonlinear process, right?!;-)).
You can see where the consumer scanner development got left behind in the steps 1) and 2) above, at least in terms of full handling at the receiver level. Perhaps the cellular arena, as it has done for other aspects of the transceiver chain, plus other high volume RF consumer devices, will result in cheap I/Q demodulators that the scanner folks can use effectively. Or else - well, "software I/Q" after direct A/D of the IF? I'm dumb, here, no clue, is that what's done in the biggie SDR stuff?
Regarding talkaround capability - that is a very good point, actually! Apparently, when the LAPD went to full P25 conventional (non-trunked) usage they ran into this issue. One would think that the C4FM signals would behave similarly to standard analog FM in terms of the capture effect inherent in FM signals. Apparently, this did not appear to be the case. Initially, the LAPD attempted to use unit-to-unit simplex channels in the same way they always had been doing when using analog FM - that is, they used the base/repeater output frequency as the simplex talk around channel. This had worked fine with analog FM but, apparently it played holy havoc with the C4FM stuff making it unworkable. I'm not sure I can explain why - if it were CQPSK or some other complex digital mode I could see problems but I am not sure why the C4FM had issues. Maybe something to do with the instantaneous transitions of frequencies and phases versus the more gradual and linear changes with analog voice. Anyway, they finally abandoned that practice and changed to completely separate simplex usage frequencies (interestingly, those new channels were used in both repeater and simplex mode but, in LAPD lingo, they stuck with calling them all "simplex" with "direct and repeat" option available). So you may have something there concerning why talk around is still preferred to be in analog FM mode. FM is also simple to use in all systems now given it is easily generated and received by all of the hardware as we have discussed and is a great fall back if everything else goes haywire and/or for the final "everybody's got it" mutual aid choice.
Everything you wrote about the I/Q demodulator used for FM makes sense and jives with what I know. Pretty sure you're right about the zero crossings and needing only one I or Q channel.
And I know all about the "little green men"! I went from a large corporate telecom doing digital cellular, DSMR, and mixed mode sat phone subscriber gear to a small startup company focusing on developing large scale RF integrated circuits. In my old company "systems engineering" referred to the infrastructure equipment development and implementation while in the new company everything outside the IC was "Systems Engineering"! So a subscriber unit to them would have been a "system" while it was just a basic user device to me. The folks there initially were brilliant in terms of IC design all of which was new magic to me but they lacked RF system knowledge and that I had (system in terms of proper layout on a pcb and impedance paths, coupling, decoupling on power leads, etc., etc., and simply knowing what was what and where when building a transmitter and receiver using the IC's they were designing). Learned a lot about the IC magic there - quite an eye opener for this "systems guy"!
Man this post got long - hope it was helpful and meaningful!
-Mike
  #91 (permalink)
Old 02-10-2013, 1:11 PM
Thanks for all Mike! There is a lot to digest there but it is all excellent. Thanks for the experience on the LAPD with the talkaround C4FM; that is quite interesting. I'll comment on that in a bit. Let me add a few tidbits that you might find interesting:
- pi/4DQPSK is not much different from CQPSK in that both have amplitide variations that one needs to maintain in the system amplification and demodulation. And, I am about 99.9% sure that cell TDMA had spectrum shaping filters; that is common to all modern digital wireless modulation to control adjacent channel power and general spectrum spread. (I think I have the old IS136 sandard, so I could look it up.....too lazy....) I really don't look at the issues of CQPSK (and HQDPSK for P25 Pahse II) any differently than the old cell TDMA modulation; you should take ALL of the lessons learned from as being 100% applicable for CQPSK/HQDPSK and Phase II P25: modulation, demodulators, linearity, vocoders, overlap delay and spread for simulcast issues, etc.
- You are spot on about the subscriber units and the non-linear PA's as for battery life and the decisions to use a talkback modulation with less/no amplitude variations. And you are also right on the newer linearized PA's these days. I was speaking to a friend in the industry just last week about this; he used to design PA's for GE Ericsson (now Harris) and is still heavily and professionally into all of this. I was asking about uplink power control on P25 Phase II (which has been included as a future system option) and he was telling me that the subscriber units now use Class AB amps (persumably linearized). The performance is such that nowdays that he says you can apply up to around 15 dB of uplink power reduction and the PA still maintains adequate linearity.
-The uplink (talkback) modulation on Phase 2 P25 is HCPM. It is constant enevelope modulation. Here is a good app note on that: http://www.aeroflex.com/ats/products...ion%20Note.pdf
- I like your 5 system deployment steps and it is VERY representative IMO of what is going on as these system deployments progress through Phase I and onto Phase II. And it is dfferent for different system manufactuers. (For example, as I understand it, LSM in only Moto.) So each individual system is going to have it's own flavor of twists and turns. For all of those who are having problems scanning P25 systems (simulcast or not), this is important to know if one wants to explain why one system/scanning combination works and why others do not. It is no wonder that scanning experiences with P25 are all over the map.
- Even if the PS mobile and portable units benefit from high volume cellular parts, I don't expect any rapid decease in prices. The market is 10's of thousands of units, not millions. With all the development going on and the cost of that R&D and the low unit numbers, it will never be cheap. It MAY get lower over a decade or 2...just IMO.
- C4FM could exhibit some of the same capture effect of FM but the same part that produces capture effect (the limiter) will produce the same amplitide distortion that compromises demodulation of any complex phase modulated waveform with non-constant envelope (amplitude variations). C4FM should not much care about limiting by itself, but my gut tells me that that when you put two narrowband, shape-filtered C4FM signals into a limiter with a symbol rate close to the bandwidth, this is not going to work out the same way. As I recall, capture effect works best when you have large modulation index (like FM broadcast or even ham 2M), but it will not do so well with small modulation indices. A smaller modulation index is effectively what you have in a high symbol rate, narrowband signal. That could also tie in with the simulcast scanner issues. BUT, that is just hinking aloud and I need to ponder and read on all that more.
BTW, capture effect is not part of FM modulation per se: capture effect is inherent in the FM receivers, and results solely from the presence of a hard limiter in the first stage of the demodulation chain. Look at it this way: for FM demod, you only care about the rate of the zero crossings of the signal; that represents the frequency. If the you really hard limit a pair of FM signals (and hard limiting means you cut off all but 1% or less of the amplitude swings around zero voltage) , the zero crossing times will be totally controlled by the stronger signal. That is the only FM you will hear and the other signal will dissappear; hence, the FM demodulator is 'captured'.
- Here is one possible thought about C4FM problems experienced on talkaround: When trying to use the subscriber unit on the base/repeater transmit frequency with C4FM in phase I, then it has to to compete with the C4FM energy transmitted from the base or repeater site. If there is no limiter in the receiver, then there is no benefit from the capture effect that existed when things were all FM. With FM capture, the mobile/portable transmitting in talkaround mode would just need to be 2-4 dB strong that the base-repeater site energy. If as speculated above, the limiter capture effect for C4FM does not really work as well as in FM, or if the limiter is not used, the reverse will result: C4FM talkaround is going to be more easily interfered with by the base/repeater site than in the old FM days. But hey, that is just one crazy idea on the matter......
(And, when CQPSK came along then the subscriber unit PA's may have not been able to do that at regular ouptut power....or at all...?)
Well, let me thank eveyone for all I have learned. And I apologize to all the readers out there who just want to fix the scanning of P25 digital in simulcast situations, this is some pretty serious threadjacking going on!! But I enjoy the chance to compare ideas with such a diverse group, and learn more and more.
  #92 (permalink)
Old 02-10-2013, 2:04 PM
KC0CSE's Avatar
Ya what ever you said....lost in Missouri.....but glad were talking about it......one of you guy's are going to fix it someday I think!!!
  #93 (permalink)
Old 02-11-2013, 12:52 AM
Thanks, beachmark for the good explanations and clarifications! I would love to keep going back and forth on them as I have a lot more questions but you are right - we need to focus on the topic and stop the thread hogging. I would like to PM you when and if that is ok for you?
Now, for the benefit of all of those exhausted readers how about we summarize the salient points regarding what we've determined among us concerning P25 simulcast distortion in consumer scanners:
1) Professional P25 subscriber equipment almost certainly employs some form of I/Q demodulator to handle the correct demodulation of complex modulations encountered in all forms of P25 implementations. Whether they also continue to include a traditional discriminator either just for FM use or for augmenting the I/Q demodulator in special circumstances is uncertain as yet however it seems unlikely as the I/Q demodulator should be quite capable of handling all forms of modulation very effectively. At least one early form of Motorola handset appears to only use an I/Q demodulator.
2) Professional P25 subscriber gear does not use nor does it need to use any form of adaptive equalization to enhance either multipath or simulcast induced phase distortion due to the forgiving nature of P25 modulated signals versus what would be found in some forms of digital cellular modulation.
3) Although it is not absolutely known yet (by us outsiders) what the two primary consumer scanner manufacturers use for demodulating digitally modulated signals it is likely that they use the more traditional discriminator or quadrature demodulator as used in older analog FM equipment and do not, as yet, use any form of I/Q demodulator. This is likely due to cost reasons.
4) P25 trunking systems use simulcast technology in order to improve coverage over large areas without having to employ extra sets of voice channel frequencies; this makes the most use of available limited resources (frequencies) at the expense of added complexity and more sites.
5) Motorola simulcast P25 systems use what is known as "Linear Simulcast Modulation", "LSM", which uses a form of CQPSK digital modulation on the outbound (site to subscriber) path. This form of modulation is complex by itself and contains amplitude information and must be demodulated in a receiver by using a I/Q demodulator for best results especially at the extremes of range and under adverse conditions.
6) The nature of simulcast distortion by itself means that it is better handled in I/Q demodulator equipped receivers than in standard discriminator equipped receivers.
7) Future P25 Phase 2 TDMA systems will also use CQPSK modulation on the outbound paths and so will also be best received by I/Q demodulator equipped receivers.
8) No amount of post processing used to correct issues from the use of a discriminator alone can ever fully compensate for incomplete demodulation of CQPSK modulation and simulcast distortion when compared to a proper I/Q demodulator implementation.
9) Future usage of I/Q demodulators in consumer scanning equipment is dependent on cost effective components becoming available; the likelihood of this happening in the near future is questionable.
10) Until such time as the use of true and effective I/Q demodulators in consumer scanning equipment is practical and profitable as viewed by the manufacturers the reception of complex modulations lacking constant amplitude envelopes and the reception of simulcast systems will remain problematic in low cost self contained consumer scanning equipment.
From the above, we can also conclude that simply blaming lack of robust error correction as the reason for consumer scanners having issues in simulcast systems is an incomplete assertion at best and completely false at worst.
That's just my summary up to this point. Does this seem accurate? Can we add more? Where do we go from here?
-Mike
  #94 (permalink)
Old 02-11-2013, 8:50 AM
zerg901's Avatar
For historical context - IIRC when the P25 standard was being developed, GE was pushing TDMA and Motorola was pushing FDMA. I think that GE was ahead initially, but Motorola won the race. At one time there was P25 wide and P25 narrow. Possibly "P25 wide" was used in synchronized simulcast systems until LSM was developed.
  #95 (permalink)
Old 02-11-2013, 3:18 PM
-Mike
Mike,
Thanks for the summary. I believe you have captured the consensus opinion.
However, I do think the conclusions are too strong, you have jumped to lack of I/Q detector - yet we don't know for sure what's in a consumer scanner. And that does not explain how some have "fixed" their P25 simulcast problem by using a high gain antenna (presumably receiving only 1 transmitter), or by using a paper clip antenna (and thereby presumably only receiving the stronger signal).
You don't mean CQPSK do you? The C in CQPSK stands for compatible - as in compatible with FM demodulation. I think you mean LSM or other manufacturers proprietary modulations.
This is no more speculation than the speculation that consumer scanners don't have I/Q demodulation.
We don't know if error correction is used in the consumer scanners - and therefore can't make any definitive statement as to it contributing or not. However, if error correction is not implemented - it would definitely make receiving a clean signal difficult. (of the 144 bits in a voice packet - only 88 are voice, 56 are error correction - so error correction is important).
  #96 (permalink)
Old 02-11-2013, 5:13 PM
rak313, good points! That summary was just to get us back on track in terms of the discussion this thread was supposed to be about - given the length and complexity of the thread and some of the posts it makes sense to occasionally stop and summarize "the story so far". It was just a first attempt at that.
But you're right - I'm probably being too bullish on the need for the I/Q demodulator. We really still don't know what the manufacturers are using. However, I still personally feel that the issue is really in the quality of the demodulator. Perhaps that's where we should get a consensus from the technical folks participating in this thread: Is the difficulty in receiving simulcast systems on low cost consumer grade scanning receivers primarily the fault of the demodulator section? If not, where else should we be looking?
Concerning what you said about the ability to use special tricks to receive simulcast systems reliably on consumer grade scanners, as beachmark, I believe, stated earlier, if the signal is of very high quality and strong then the low grade (relatively speaking) demodulator can handle things decently and everything works. However, if the quality degrades enough then the reception becomes problematic. One of the key characteristics of simulcast P25 signals is that they arrive simultaneously from multiple sites and you hope they are all in phase or close enough for the receiver to handle without issue. What using a directional antenna does is allow the user to point the antenna to the most desirable site and favor only one signal thereby reducing the phase distortion in the receiver. "Most desirable" does not always mean the strongest or the closest - it means the best quality signal and in the direction that rejects the most undesired signals at the receiver's location. This trick has worked well for hobbyists but, as you can imagine, is problematic for mobile and portable usage. The point is, professional gear, as long as it is operating within the designed for coverage area of the simulcast system, does not need to do this but consumer grade gear does, even when in the area of operation. Outside of the designed for area of coverage, it is most likely that even professional gear would have to use this trick however I have never heard of cases where that has been done. Now, as to the "paper clip antenna" trick, essentially, it's doing the same thing as far as receiver's internals are concerned - rejecting all but the best quality signal so that the receiver's demodulator does not "see" multiple signals interfering with each other. By reducing the quality and size of the antenna you are lowering the levels of all signals reaching the receiver; the hope is that there is one strong signal in the mix that will dominate enough so that if you keep lowering the levels the competing signals will fall below the threshold of being a problem for the receiver and allow the best and strongest signal to again dominate so that the demodulator again has a usable signal to deal with. As you can probably guess, this technique may not always work in all cases but it can prove effective in some cases, is cheap and easy to implement and is worth a try in a pinch especially when you cannot use a directional antenna due to portable or mobile usage.
Now, you're question about CQPSK is a good one. I have to admit to being confused on this point myself. In my experience, any form of QPSK is going to need a I/Q demodulator because they will have amplitude information of importance at the receiving end (at least for the BEST quality of reception under all conditions). So, I was aware that the C stands for "Compatible" as in "compatible with FM" for both C4FM and CQPSK; however, I assumed that the compatibility was relative. As we have discussed, under good conditions, a simple discriminator will effectively handle such signals but it is when things start to deviate far enough away from the ideal that better demodulators start to become important. Now, the question is, how "compatible" does that "Compatible" mean or need to be from the professional system designers and users perspective? They are not designing these systems to be "compatible" with all listeners of the system but with the actual subscribers and users of the system. I really don't have the answers here. This is a very good point and one which I intended to bring up earlier and had forgotten about. It may be that "compatible" in the current sense is that the expectation of the system designers is that all equipment used on the system will have demodulators that can handle all such signals well enough - those types of demodulators may or may not be in an outside listener's equipment but that is not the concern of the system designers and users. Now, I'm pretty sure that the compatibility in C4FM signals was originally intended to mean compatible with all forms of basic analog FM reception and transmission. That is, no need for linear PA's in the transmitter and no need for any special demodulation techniques in the receiver. However, moving up to LSM and, I would think, QPSK, I am not sure if that original definition of "compatible" still relevant. It may be that by the time these techniques became widespread in usage the designers expected that the equipment used on the system had been sufficiently upgraded to handle the new and more complex types of signals. On mixed mode systems the analog users wouldn't really have issues with phase distortion (outside of obvious voice quality issues) so even if they use analog FM only gear they should be OK with one exception - the control channel. That, of course, would have to be receivable under all designed for conditions by all users so one would expect that the receivers would be designed to use that properly. Again, here I have to admit ignorance - is the quality and composition of the control channel output sufficiently different from that of the voice channels so as to make the demodulator choice in the receiver a major point all the way around? I know, that was a confusing question and I admit I didn't frame it well but can't think of exactly how to state it. I guess what I am saying is that, since control channel based trunking systems have always needed to use a "control channel" which contains data necessary for the proper operation of the system by all users then those users have always had to be able to receive that control channel effectively from day one of the system. I actually don't know a lot about the kinds of control channel modulations used in the early systems beyond the stated baud rates (3600 baud for the early Motorola systems) so I can't speculate much here. But the point is that the subscriber equipment has always been designed to handle the transmitted control channel demodulation all the way back to the earliest analog only systems. Whether that means they designed this around basic FM discriminators or something of higher caliber, I don't know. But, if the early designers felt that the best option for best results was to use something like I/Q demodulators at least for the control channel reception then that may have pushed the professional subscriber designers to include that in the equipment early on. Again, obviously, you don't need to use more than a discriminator but, for better quality something better might be advised in highly critical situations. So, maybe the use of an I/Q demodulator in professional subscriber trunking capable equipment was instituted even before digital voice became commonplace. That is pure speculation on my part - I don't have the answers. Again, you bring up a good point concerning what they really mean by "Compatible". At some level, even CQPSK is receivable by using a basic discriminator so it IS compatible - the question is, how far do we want to take that because beyond a certain point in signal degradation outside of the ideal that simpler system might not be the best choice. What we DO know for sure is that the professional subscriber gear has demonstrably better reception quality of simulcast systems when within the desired coverage area than that experienced in consumer equipment to a serious enough degree that it is very noticeable and impacts the consumer experience very negatively. The only other thing I can think of is that the CQPSK modulation is somehow shaped in such a way that a common discriminator is completely ok. I can't understand that based on my experience but that's just my ignorance. However, two questions come to mind if we make that assumption: 1) Why do the subscriber gear designs we have seen include I/Q demodulators if a basic discriminator would be completely fine and cheaper? and 2) If discriminator demodulators are all that is required under all conditions then why do consumer grade receivers have so many issues? Then the answer to the second question would have to be that the demodulator quality has nothing to do with the issues such equipment has.
Now, I agree that we can't absolutely and definitively throw out error correction as a factor especially if we do rule out the demodulator as the critical point. I thought that I indicated that it wasn't completely ruled out in my last post but I guess my bias came out too strongly. I am of the opinion that it is thrown around and used too casually as a catch all for all ills. My professional experience leads me to question that assumption strongly. For a hobbyist with little technical background in this area it is easy to get one's head around but to someone with an engineering background in such things I cannot help but question it and make absolutely sure that we rule out all other factors before claiming that that is the entirety of the problem. Even so, you are right, that error correction alone is not where to look for the cause of the problems we are discussion is an assumption made by me and some others and could be false. If we find out that is all there is to the problem then so be it - we should not rule it out at this stage.
I am a hardware guy so that is my bias - I tend to look at things from that perspective and it shows. If everyone (or a strong majority) with sufficient and relevant technical background participating in this thread collectively arrives at downgrading the demodulator in importance and upgrading the post demodulated error correction (or some other aspect of the receiver design) then that is how we will proceed.
-Mike
  #97 (permalink)
Old 02-11-2013, 5:29 PM
You make a good point regarding P25 wide and P25 narrow. I wonder about those too. I'd like to understand them better in terms of the differences between them (I would guess transmission bandwidth and receiver IF filter bandwidth). That would certainly impact scanner receivers in that consumer scanner equipment likely only has one IF filter so would be a compromise solution in receiving these two formats of P25. How this impacts the simulcast issue is uncertain at this point but your point about using the wide version outside of LSM is interesting but I am too ignorant about this to speculate at this stage.
-Mike
  #98 (permalink)
Old 02-11-2013, 6:25 PM
I just came across this Dec 2008 thread
P25 LSM (Linear Simulcast Modulation) Difficulties
Edit: I removed my comment about the lack of I/Q detector in radio shack. I miss-read the thread. He is talking about no I/Q in a software radio block, not the radio shack scanner.
  #99 (permalink)
Old 02-11-2013, 8:08 PM
Just so I'm clear on this - y'all are debating whether or not scanners perform simple Golay error correction on P25 voice frames? Or whether they do it robustly? How does one do Golay FEC non-robustly?
  #100 (permalink)
Old 02-11-2013, 10:47 PM
MississippiPI's Avatar
What????
Be safe
MississippiPi
Copiah County, MS.
