Old 02-14-2013, 10:11 AM
Default Good beginner scanner
Hey everyone,
I'm looking into getting a good scanner just for home use, although I think I would rather have a hand held. I live in WA state, and I dont mind spending a little bit on it if needed. What would be a good brand/scanner to go with? Thank you.
Old 02-16-2013, 7:53 AM
Rt169Radio's Avatar
Send a message via Yahoo to Rt169Radio Send a message via Skype™ to Rt169Radio
Hello, where exactly in WA do you live?
Old 02-16-2013, 9:59 AM
I live in Lewis County in western WA
Old 02-16-2013, 10:14 AM
Also on 2nd thought, maybe a good base scanner instead/also. I'm not sure I like the being able to accidentally transmit thing. Thanks!
Old 02-16-2013, 3:19 PM
captclint's Avatar
Mentor
Originally Posted by wb88 View Post
\ I'm not sure I like the being able to accidentally transmit thing. Thanks!
Don't worry, you can't transmit on any scanner, so it all about the convenience for you. A base unit usually has little larger screen, and better keypad layout. A handheld is obviously more convenient if you want to take it with you for any reason. Both perform exactly the same...IE you might say the only difference is the case. I use a handheld exclusively at home, but I do use monitoring software that allows me to see the screen even larger than a base unit.
There doesn't seem to be many frequencies for Lewis County, WA
What I see are all conventional, which means you don't need a very expensive scanner. My favorite would be
BC125AT - The RadioReference Wiki
However, I would go to the Washington State forum and ask the question about what would be best. They may know of a more sophisticated system coming on line soon that would require you to get a trunking scanner.
Regards,
Clint Chamberlin
Luzerne County, PA
Old 02-16-2013, 7:05 PM
Okay thank you! I was lookig into the Uniden Bearcat 346XT a little bit, its $80 more than the 125AT, you think it would be overkill? Thanks again
Old 02-17-2013, 8:07 AM
captclint's Avatar
Mentor
I have it, and I love it, BUT it is overkill for your area at this time, UNLESS you would be interested in listening to business type com's, including trash haulers, concrete trucks, contractors, plumbers, school buses, transportation, etc. They tend to be analog trunking, but you would have to search for them, if any, since there are none listed for your area now.
If your area does get into pulbic safety trunking, it will likely take a few years, and you could get a better scanner when that happens(they all improve every 2 yrs or so). You can't go wrong with 346, but I would still check with WA forum in case there are plans to go digital, in which case the 346 would not work. For example, U.S. Dept. of Justice: Integrated Wireless Network (IWN) would require a digital scanner NOW, if you wanted to monitor this.
Regards,
Clint Chamberlin
Luzerne County, PA
Old 02-18-2013, 6:11 AM
wb88...if you don't need a scanner for trunking or 800 MHz (which it doesn't appear that you do), I would highly recommend the BC125AT. It is a great scanner and is fairly easy to program. I bought one recently for my vehicle and am very impressed. If you have any questions, I'd be happy to try to answer them. Just PM me.
Dave
Dave
My Scanners: Uniden Bearcat BC355N, Uniden Bearcat BC125AT
