Old 03-06-2013, 5:14 PM
cyclone27's Avatar
Default Network - stream losses connection.
Just recently i've moved 2 feeds to another location, because of a power supply issue.
No problem, its just that the stream is not 100% connected. It would work for 5 or so minutes then the feed would drop out.
The setup is as follows:
ADLS-cable-Router-cable-switch-cable-AP-wireless 400m-AP-cable-switch-cable-computer
i think something is faulted (cable, switch ) is there software i can buy to diagnose the problem ?
if this topic is in the area, please move.
cheers
