Old 07-07-2013, 9:03 PM
Default NMO hole wave/uneven?
I recently purchased a 2003 Crown Vic decommissioned police car. About to use a NMO hole that was already drilled in the roof for a antenna to run my BCT15X. However today i pulled the plug and there is a slight wave/unevenness to the roof at one part of the hole. Also some paint is missing around the hole (no rust). Am I going to run into leaks/problems with this? Or when I install the NMO mount will that "flatten" the wave/unevenness? What could I do about the paint missing around the hole? I performed a search here and it turned up nothing, but I am sure that someone has run into this before.
Thank you before hand!
BC-72XLT --- PSR-500 --- BCT15X ---BCD536HP
Feed Provider Cherokee County, GA
WQZC882 GMRS
Old 07-07-2013, 9:36 PM
n9mxq's Avatar
Don't sweat it. Someone pushed too hard drilling. If the missing paint is on the inside that's good. It's how NMO mounts achieve ground. If its outside use touch up paint.
You may never get the wrinkle out. But it's no worry.
No bits were harmed in the posting of this message.
Gene
Transceivers, receivers, and SDR! Oh My!
Old 07-07-2013, 10:34 PM
Skooter92's Avatar
Default NMO holes.....
Check out this thread.. http://forums.radioreference.com/sca...r-gaskets.html. Some valuable ideas and discussion. Good luck!
__________________________________________________ _________
“You can't make anything idiot proof because idiots are so ingenious.”
― Ron Burns
Old 07-08-2013, 5:16 AM
n9mxq's Avatar
Thanks Skooter,
I forgot all about that thread..
Gene
Old 07-08-2013, 5:56 AM
Thanks you guys! Feel better about it now. was thinking that I ran into a big problem. The mount should be here in a few days so we will see how it goes!
WQZC882 GMRS
Old 07-10-2013, 8:08 PM
n9mxq's Avatar
Keep us posted on how it goes.
Gene
Old 07-10-2013, 8:55 PM
Will do. mount has shipped and should be here end of this week or first part of next week. Thanks guys!
WQZC882 GMRS
Old 07-10-2013, 9:43 PM
the bend is from an antenna getting snagged at a car wash. We have fixed those plenty of times..Unless the hole is ovaled they shouldn't leak once a new NMO is installed
Old 07-15-2013, 5:42 AM
Thumbs up
Installed mount and antenna late yesterday. everything went great! Water tested mount when done, NO leak!. you all were correct!
WQZC882 GMRS
