Old 11-05-2013, 2:05 PM
vindictive42's Avatar
Cool scanner choice for aircraft
I am thinking about buying another scanner for aircraft monitoring and need to know which one would suit my needs. I have looked at the icom r6, ar120, bc125 and the bc75xlt. I am looking for a small compact scanner with good audio, low battery consumption and has to have close call feature. So far it looks like bc125 or bc75xlt. which one is better.
thanks
Old 11-05-2013, 2:10 PM
pinballwiz86's Avatar
My BC125AT works great for civil air. Make sure you get a better antenna. I like the RadioShack center loaded telescoping antenna.
Are you going to be monitoring mil air? The BC125AT is missing part of the frequencies in the band. But, other than that it's a doozy.
Scanners:
Uniden BC125AT // Uniden BCD396XT
Amateur Radio:
Icom 718 // Baofeng UV-5R+ // Yaesu FT-2900R
Old 11-05-2013, 8:31 PM
ShyFlyer's Avatar
The BC125AT and the BC75XLT look to be just about the same, with the BC125 having Text Tagging capability and more available channels. The BC75XLT will of course be less expensive.
I'm very happy with my BC125AT. The extra channels isn't so much of an advantage for just scanning the aircraft bands, but the Text Tagging is fantastic!
Old 11-06-2013, 5:50 AM
dmg1969's Avatar
Default scanner choice for aircraft
I will also speak in favor the of BC125AT. I don't monitor air often...usually just when picking up/dropping off relatives at the airport. On the rare occasion that I do, it works great.
Dave
My Scanners: Uniden HP-1, Uniden Bearcat BC125AT and Uniden Bearcat BC355N
Old 11-09-2013, 9:13 PM
b7spectra's Avatar
EMS Dispatcher
See if you can find a Pro-43. One of the best ever RS scanners on both civil & military air band!
\/\|k.e
EMS Dispatcher/EMD Certified
http://icanhasdriverslicense.com
Old 11-09-2013, 10:58 PM
N8IAA's Avatar
thanks
The 75 doesn't do milair. The 125 does. So, if you aren't interested in milair, go for the 75. Keep extra batteries around for the 125, though. I do monitor A/A refueling on the 125, it actually beats my 15X.
However, my Alinco DJ-X11 beats the 125 for VHF/UHF comms, and the Li-ion battery lasts nearly forever! Better audio too.
Just thought I'd throw in my TCW
/\/\ike is right about the Pro-43. Absolutely the best HH I ever owned for monitoring aircraft comms hands down.
HTH,
Larry
Digital/Analog scanning and hamming
