Old 01-03-2014, 6:45 PM
Default Weather freq bleeding on into other channels
MY 396XT is picking up the local 162.4750 NOAA chan on several of my channels-155.625,155.925,151.2725,155.895, and a few more. My HP does not and also my RS pro 2046 has the problem as the 396xt. Am using a ST2 w/50' RG6. I will admit I have splitter and a TV amplifier in the system. My tower is within 3 miles. I have always had problem with NOAA bleeding in my pro 2046 if I was within a 3 block of the tower. My zip is 64429. What changes do you think I should take?
Old 01-03-2014, 7:07 PM
maybe a band pass filter? attenuation?
BCT-15
BC-72xlt
Pro-106
Old 01-03-2014, 7:32 PM
trsundstrom's Avatar
Mentor
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 4.1.2; en-us; DROID BIONIC Build/9.8.2O-72_VZW-22) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
I'd start by removing the amplifier from the configuration. Receivers' front ends are probably overloaded. HTH.
Tom - W2XQ - w2xq.com
RS PRO-2041 & PRO-106
Old 01-03-2014, 7:34 PM
Mentor
Mentor
Old 01-03-2014, 8:15 PM
I eliminated the tv amp. Will let you guys no tomorrow etc.I don't really how to change the attenuation on the 396xt but HP is easy.
Old 01-03-2014, 10:25 PM
wtp wtp is online now
Default a better question
do you need an outside antenna?
if what you listen to is local you may not need it.
to set attenuation on 396xt it is either under system or site settings
a friend of mine had to get an outside antenna even though his county tower is 1 mile away.
just have fun
Old 01-03-2014, 10:42 PM
kg4ojj's Avatar
When in Americus, GA, I have this same problem. No attic or rooftop antenna, though. On my PSR GRE-410 scanner, I use global attenuation and it works. I still have to lockout some frequencies.
Would anyone have a specific recommendation for a notch filter to exclude weather radio interference???
Jay Reid ~ KG4OJJ
Old 01-04-2014, 11:15 AM
ChrisP's Avatar
PAR Electronics makes some filters specifically for the NOAA VHF frequencies:
PAR Electronics | Filters for the commercial 2 way market, MATV, FM broadcast, laboratory, marine industry, amateur radio, scanner and short wave listening enthusiasts
- Chris
Chris Parris
The Spectrum Monitor Magazine, www.thespectrummonitor.com
chrisparris@thefedfilescom
http://mt-fedfiles.blogspot.com/
Old 01-04-2014, 5:09 PM
KevinC's Avatar
Moderator
Originally Posted by ChrisP View Post
X2 on PAR Electronics, Dale is top-notch!
BC-210XLT
"Wise men speak because they have something to say; Fools because they have to say something."
Old 01-04-2014, 9:12 PM
Contacted PAR about getting a filter etc. Yes, I have outside antenna inside. I sure hate to eliminated some channels. Haven't tried to change attenuation, not really handy like the HP1.
Old 01-04-2014, 10:02 PM
Default wow
for the 396t attenuation is by system
but for the 396xt it is by frequency in the systems so
program system
elect system
edit group
select group
edit channel
select channel
set attenuator
ok more than a mouthful
hope it helps
Old 01-05-2014, 10:00 AM
Boy, that was easy. Now I will see if that works on several channels. wtp-you are better then <easy to read format>. Thanks
Old 01-05-2014, 12:57 PM
Default but...
did you try the radio with just the regular antenna.
try a radio shack 800 mhz antenna if that is the band of choice for that radio.
the idea is to cut (attenuate) reception of the band that you don't want.
when going down a main road here all kinds of 800 mhz crap gets into the sheriffs system on my 396t.
it was easier to get a stubby antenna (one and a half inches) then to turn on the attenuation.
there is a cell tower a few hundred feet from the sheriffs tower. the other way is to remove the antenna and yes it will receive strong signals. it is easy to see if a transmitter is close
the amatuer folks call it fox hunting (find the transmitter)
play around and see what happens
on receive only there is no rules
even a bent paper clip is an antenna!
have fun
Old 01-09-2014, 7:28 PM
wtp---no I didn't try another antenna but just clicked yes on the attenuator to shut off for the few channels that was bothering and it worked so far now. I don't know what happens when I shut my phone off as far as the memory remembering it.
Old 01-09-2014, 8:52 PM
Default ?
i know you wrote phone but meant radio
once you change the setting it is set
good luck and have fun
Old 01-31-2014, 11:39 AM
I had the same issue with NOAA Wx interference on my handheld scanner and a cheap RS stubby or "race" antenna fixed me right up.
Uniden BC92xlt, BC200xlt (ret.)
Old 01-31-2014, 1:27 PM
kb5zcs's Avatar
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_2_1 like Mac OS X; en-us) AppleWebKit/533.17.9 (KHTML, like Gecko) Version/5.0.2 Mobile/8C148 Safari/6533.18.5)
Remove the preamplifier,you might be over loading the front end of these radios most scanner have weak from ends.......
