Old 02-20-2014, 8:48 AM
Default How to tell if a system has rebanded
I'm looking through the RadioReference database and programming my scanner using ARC software. For some 800Mhz systems I'm prompted to Reband. How can I tell from this database whether or not I need to set the system up as rebanded?
Thanks in advance.
Old 02-20-2014, 11:52 AM
Check out the RadioReference link here for some help.
ICOM R-1/R-71A/R-7000, Satellit 700
PRO-2006/163, DX-160/302/398
and a ton of "boat anchors"
Old 02-20-2014, 12:07 PM
The correct link should be
Rebanding - The RadioReference Wiki
Tom
Old 02-20-2014, 10:56 PM
DickH's Avatar
Thanks in advance.
If any of the freqs. you want to monitor have a zero in the 4th decimal place, it has been rebanded. (e.g. 851.2250)
Dick H
http://dickh.zenfolio.com
Old 02-21-2014, 5:51 PM
Also, when monitoring some rebanded TYPEll Moto systems and all of a sudden you see the freqy and conversation just flashing or blinking the system is rebanded and scanner choosing the wrong #'d freqy.....
RoninJoliet
Old 02-21-2014, 9:00 PM
That can't be right. Orange County, CA hasn't yet rebanded, but several of its frequencies have a zero in the fourth decimal place. That system has been in place for over 13 years now.
Old 02-21-2014, 10:10 PM
n5ims's Avatar
I think what he was getting at (but in no way made it clear) was that is only important in the 851, 852, & 853 MHz frequencies. Those are the ones that were "rebanded" from the original 866, 867, & 868 MHz frequencies.
Tags
rebanding
