As noted, encryption can be put to use but typically most (and by most I mean the majority) of systems worldwide still don't use it and when they do they tend to encrypt specific channels that just need to have it in use (and on those channels or talkgroups it's understood, like perhaps a S.W.A.T. channel where you really wouldn't want someone in a hostage situation being able to monitor every transmission they happen to be making in the process of a potential incursion or rescue, obviously).
The point being: encryption does serve a purpose. I'm a person that's been monitoring for many many years, several decades actually (since the early 1970s) and I understand that some stuff shouldn't be on the airwaves and if it does happen then encryption becomes a way to ensure even if someone keys up a mic and spills the beans so to speak the info is still "safe" from the casual or even somewhat dedicated monitor - and yes, criminals and ne'er do wells included.
I fully believe that as a member of the general public that we as citizens do have a right to monitor our public safety services to some degrees - it's pretty commonly understood that typical dispatch channels are acceptable to monitor without issues but when it comes to tactical, narcotics, investigations, and many other types of traffic that stuff is best kept under wraps which means encrypted and I don't have any problems with that. My problems come in when a radio system is put into use (be it analog or digital) and the people in charge of creating the system or managing it decides to encrypt all of it start to finish with nothing being available for monitoring by the general public.
There's a difference between having a radio system that cannot be monitored because there are no scanners that can decode the content (OpenSky is one such system) or software applications that could potentially decode the content (like DSD or DSD+) and having a system that can be monitored either directly by scanners or by using (again) software like DSD or DSD+ but it's encrypted which would then slam the door on potential monitoring.
Honestly encryption has always been and will always be a hot-button topic in this community, you'll find those that are totally for it 24/7 on any and all systems, and then you'll have the rest of us like myself that say "I got no beef with some sensitive content being encrypted but I believe there needs to be an accommodation made for the general public to be able to monitor what's going on as long as it actually IS something that can be monitored with available technology." For OpenSky, there's just no technology, period, aside from those actual units on that system and the general public just can't get that kind of hardware for a variety of reasons.
Even ProVoice - the not quite so popular in terms of widespread use but in the areas it is used in they happen to have fairly large populations and systems as recently shown by Uniden's addition of ProVoice decoding for their latest scanners as a pay-for-play upgrade) has been able to be monitored for some time using DSD+ but the majority of people won't go that far to do it, they just accept that no scanner could do it and that was that. But of course that's changed now with that Uniden upgrade that adds support for it and a lot of people are very happy about now being able to listen in.
But enough of my babbling: there are dozens upon dozens of threads here at RR about this kind of topic including encryption so, rambling through past threads or doing a search for "encryption" in the topics of the threads specifically can net you a great deal of info and opinions.
For a few years the residents of Las Vegas and nearby cities couldn't monitor our own Metro PD because they were using OpenSky - that system was basically garbage and they eventually moved over to a P25 Phase II system which has been up and running for roughly a year now with testing phases before it went "live" 24/7. Luckily, they're leaving the dispatch channels open at least for now so that we're able to monitor those comms which is greatly appreciated by myself and many others. The rest of the system is encrypted and I have no issues with that at all as long as they do keep the dispatch ones available.
We got lucky with this particular situation, that's not to say at some point they won't just flip that switch and encrypt everything leaving residents high and dry, but it's always possible.
As far as trunking itself is concerned, I've yet to see a system that can't be followed properly these days using Unitrunker or perhaps the donation version of DSD+ aka the "fast lane" release which I believe can do DMR/TRBO system trunking now and maybe even NXDN too (I don't know about either of those 100% so I could be wrong on that). Trunking isn't a problem and I don't expect it to factor into the situation but, I'm speaking as someone that doesn't even own a physical scanner anymore - I use my laptop and some "cheap USB TV tuners" aka RTL sticks to do all my monitoring duties so, the sky's the limit as long as someone is able to create software applications to control the hardware and decode the signals.
