Closed Thread
Old 03-20-2006, 6:43 PM
Default What does DEC & HEX mean?
Hi,
When looking at the databases on RadioReference, I see three columns on the left side of some of the pages shown as: DEC HEX Discription.
I was wondering what these mean.
Thanks,
Born-again newbie
Old 03-20-2006, 7:01 PM
They are the talkgroup numbers. Dec is decimal, Hex is Hexidecimal. Both represent the same number/talkgroup.
Best Regards,
Bill
Duct tape is like the force. It has a light side, a dark side, and it holds the universe together.
DEC= Decimal. This is the one that you program into your scanner.
HEX= Hexidecimal. This is NOT for scanners, it's used in programming motorola radios.
Colin Taranovich
-- Whistler TRX-2, GRE PSR-500, RS PRO-2055, RS PRO-93, ICOM IC-A24
Old 03-20-2006, 7:02 PM
scannerfreak's Avatar
Moderator
Welcome!...Check out the Wiki! A must see for newbies.
Forum Rules and Guidelines
Old 03-20-2006, 7:25 PM
Hir8ed_2's Avatar
DEC is Decimal and HEX is Hexidecimal. What most electronics and such are programmed to understand long with BINARY. All math terms.
Hir8ed_2
Old 03-21-2006, 2:35 PM
kb2vxa's Avatar
Hi Hir8 and all,
Don't forget octal just to confuse them. (;->) Corpus Christi is Spanish for "body of Christ" but I have no idea what a "copus" is. Check your spelling.
Old 03-27-2006, 9:35 AM
Hir8ed_2's Avatar
Default Hex, Dec, Oct, Bin, Alpa Numeric...
How's that?
Hir8ed_2
Old 03-27-2006, 9:48 AM
Hir8ed_2's Avatar
Thumbs up Corpus - - Copus you get it?
Originally Posted by kb2vxa
Hi Hir8 and all,
Seems you knew enoough to figure it out, right? Just checking on your little remark.. I'll try real hard to never make another mistake typing at the sie, ok? Please forgive me.
Hir8ed_2
Old 03-27-2006, 1:34 PM
hotdjdave's Avatar
K9DJW - Senior Member
Post Definitions
Hexidecimal (correctly spelled HEXADECIMAL; even more correctly termed, Sexadecimal) - HEX:
http://encyclopedia.thefreedictionary.com/Hexadecimal
In mathematics and computer science, hexadecimal, or simply hex, is a numeral system with a radix or base of 16 usually written using the symbols 09 and AF or af.
For example, the decimal numeral 79 whose binary representation is 01001111 can be written as 4F in hexadecimal (4 = 0100, F = 1111).
DECIMAL - DEC:
http://encyclopedia.thefreedictionary.com/decimal
Decimal notation is the writing of numbers in the base-ten numeral system, which uses various symbols for ten distinct quantities (0, 1, 2, 3, 4, 5, 6, 7, 8 and 9, called digits) to represent numbers. These digits are frequently used with a decimal point which indicates the start of a fractional part, and with one of the sign symbols + (plus) or − (minus) to indicate sign.
Discription (correctly spelled DESCRIPTION):
http://encyclopedia.thefreedictionary.com/description
A description consists of an enumeration of the quantitative and qualitative parameters which define something, that is, what something looks like, sounds like, feels like. A complete description includes useful subtle differences which can be useful for distinguishing one thing from another and general characteristics commonly noticed which in popular culture define something. Rigorous description is created and used in scientific disciplines as technical terminology.
Since someone mentioned it; OCTAL:
http://encyclopedia.thefreedictionary.com/octal
The octal numeral system is the base-8 number system, and uses the digits 0 to 7.
OK, maybe I am being a smarty, but these are the definitions.
KCChiefs9690 is acurate in the application to scanners/communications:
Dave - K9DJW
Whence came you and whither are you traveling?
Old 03-27-2006, 2:05 PM
loumaag's Avatar
Silent Key - Aug 2014
Asked, answered (a lot) and to stop any further burning, this thread is closed.
Closed Thread
