Old 04-21-2017, 8:22 AM
Default Under $250 bucks
I need to get a scanner that is handheld and digital for less then $250.00 if possible. I am retired so money is an issue and I would purchase on Amazon.
I am interested in two states, MN and WI and to narrow this down in WI, Polk, Burnett Coumties. In MN it would be Chisago, Pine and Washington,
I have a Yaesu FT-60R radio and from what I here is that it does not make a good scanner.
Thanks for your Help.
Jim, Cushing, WI
Old 04-21-2017, 9:25 AM
DJ11DLN's Avatar
The wiki here will tell you what you need to know about the systems in those locations, and what type of scanner will let you monitor them. Beyond that, eBay, craigslist, LetGo, etc often have affordable used scanners on them. I saw a WS-1065 near me on LetGo yesterday, allegedly still NIB and never programmed, for $120. So deals are out there, you just have to look for them. Check the classified section here too.
If it looks stupid but it works...it ain't stupid.
Old 04-21-2017, 10:23 AM
marksmith's Avatar
You are looking for something used for that price range.
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
Old 04-21-2017, 10:49 AM
Your best bet is to check Craigslist for the models mentioned above. There is a desktop Uniden 996T on the Minneapolis Craigslist for $175.00 even though you want portable. Just be patient, they pop up enough.
Old 04-21-2017, 10:56 AM
https://www.amazon.com/Whistler-WS10.../dp/B00IID3OAY great p1 scanner
Scanners: BCT-15, Pro-106, Whistler 1040
Radios: Icom 3161, Connect Systems CS580
John 15:13 - Greater love hath no man than this, that a man lay down his life for his friends.
Old 04-21-2017, 11:39 AM
marksmith's Avatar
Originally Posted by reconrider8 View Post
This is likely the only new scanner out there that is p25 digital and in the price range requested. You might also run into a discontinued 396xt, which is probably a better radio, but the price has been holding on those since they were discontinued.
Old 04-21-2017, 6:45 PM
Hey say what you want it does what I want it to do
