Old 12-06-2017, 4:30 PM
Default Why am I getting these out of band signals
My AOR 82090 MK3 (unfortunately, just a stock telescoping antenna) is tuned to 145.8000 Mhz WFM, as I am trying to get ISS SSTV. Nothing yet from the passes, but when I play back the mostly static audio, I pick up a lot of weak signals of what sounds to be FM radio. Sometimes, more than one signal comes in at a time.
Why am I getting this? Could this crap be causing me not to pick up what I want to?
Here is a clip of what I am talking about:
https://soundcloud.com/user-437184959/interference
Old 12-06-2017, 5:18 PM
KK4JUG's Avatar
I've never tried to pick up ISS but I suspect you need a more directional antenna. The stock antenna is going to give you the next county, if you're lucky. ISS is about 250 miles away. Admittedly, it should be a clear shot, though.
Also, I think they only transmit intermittently.
Old 12-06-2017, 6:30 PM
Yes, KK4JUG is correct. The ISS does not transmit SSTV often. I is unlikely you'll hear anything on an inside antenna...........except the FM stations overloading you receiver!
Old 12-06-2017, 7:24 PM
It is transmitting now:
https://amsat-uk.org/2017/11/29/slow...space-dec-5-6/
Old 12-06-2017, 10:21 PM
robertmac's Avatar
Just heard it as well and they were going to.
Old 12-06-2017, 11:14 PM
You'll have much better success receiving the ISS if you use a circular polarized antenna, commonly known as an "egg beater" due to the fact that it mostly looks like one. These antennas aid in tracking a satellite or, in this case, the ISS through the sky without using a beam antenna and, to some degree, compensating for the Doppler effect.
Good luck,
Jim - W8LGZ
Old 12-07-2017, 3:44 AM
If you didn't notice the interference while listening live it is probably AM detection from the recording cable that pick up local AM stations. Put a ferrit core on the cable. https://www.amazon.com/s/ref=nb_sb_n...ds=ferrit+core
/Ubbe
Old 12-07-2017, 4:51 PM
n4yek's Avatar
Originally Posted by dragon48 View Post
..... is tuned to 145.8000 Mhz WFM
As for monitoring the ISS SSTV, I do just fine with a simple quarter wave ground plane.
But I noticed something you said, you were tuned to 145.800 WFM?
That might be a problem right there, amateur radio does not operate WFM.
If anything just set you radio to FM or NFM (narrow FM) which would probably eliminate your faint FM Station audio.
Danny
A blood donor saved my life (Matthew 26:28)
If 'con' is opposite of 'pro', is Congress the opposite of progress?
Old 12-30-2017, 7:09 PM
scanmanmi's Avatar
Height of the ISS
Second place is the first loser.
Old 12-30-2017, 7:27 PM
Thanks - I had come to this same conclusion and was able to get one picture with the NFM setting.
Old 12-30-2017, 9:25 PM
KK4JUG's Avatar
Originally Posted by scanmanmi View Post
That's what I said. Your chart is in km and I quoted miles. 404 km = 251 miles
If you can read this, thank a teacher. If you can read this in English, thank a vet.
