Old 06-01-2018, 7:12 AM
Ensnared's Avatar
Default Why no alternatives to RR?
Here is something I don't fully understand. Why aren't there any alternative sources of radio information other than RR for downloading purposes? I know it is possible to manually program radio systems, but owning a Whistler or Uniden requires information to be obtained from RR via internet. I don't see any other option listed in Sentinel or ARC. If competition is so wonderful, why is there no competition? It seems RR has the monopoly. I also understand that RR relies on the hypervigilant eyes of listeners. But, I would gladly pay more for another source, provided it was a good one. Any thoughts?
"If Jesus was alive today, he would not get through American Customs." Daniel Sloss
Old 06-01-2018, 7:24 AM
jonwienke's Avatar
https://en.wikipedia.org/wiki/Network_effect
The scanner manufacturers use RR as a data source because it has the largest network of active contributors.
RR attracts the most contributors because the scanner manufacturers use it.
You're free to build a web site with a frequency database, and attempt to recruit contributors nationwide, but you'll have to invest a lot of time and money to hope to rival RR.
Gone camping.
Old 06-01-2018, 7:35 AM
KK4JUG's Avatar
If you really look at the database of frequencies and other information, you'll find it's quite complicated and extensive. It is not something that was put together last week. It's years of accumulated entries and updates. Short of copying RR information, another source like this would be more than anyone should be required to undertake,
You said you "would gladly pay more for another source, provided it was a good one." Why? There's nothing wrong with this one.
If you can read this, thank a teacher. If you can read this in English, thank a vet.
Old 06-01-2018, 8:01 AM
Just curious, what more information do you need?
Sent from my SM-N950U using Tapatalk
Old 06-01-2018, 8:15 AM
W3JMC's Avatar
Not true. Digitalfrequencysearch.com is a source for P25, DMR & NXDN frequencies with options to export to Sentinel, EZScan or Butel Arc536. It does not rely on user submissions like RR does but still, it's another source. You can also copy + paste or export data from FCC's ULS database into these programs
John C.
RX: Uniden BCD436HP, BCD536HP (2), BCT15X, BCD996XT & Whistler TRX-1.
AOR AR-DV1, SDRPlay RSP2, Others not listed here
TX: Kenwood TH-D74, ICOM ID-51A & BTech UV-5X3
Old 06-01-2018, 8:21 AM
troymail's Avatar
Silent Key
ULS is the source for the DigitalFrequencySearch site.... and is only a "starting point" based on FCC license data - full of errors and speculative (we might in the future or have in the past) information.
RRDB is somewhat more reliable but the degree to which varies greatly depending upon the area and the willingness of people to both submit and maintain the information. There's lots of missing and old/inaccurate data in some locations.
As I understand it, there are many "local" resources that some use (other than RRDB) - but again, this varies depending on the area....
I generally prefer competition vs. monopolies also but in this situation, given it's pretty much an all a volunteer effort, alternatives including some of these localized "side" resources result in neither being complete and accurate for wide-area and general use...
Unication G5(UHF)
Old 06-01-2018, 8:22 AM
jonwienke's Avatar
And those sites only have license info, which in most cases does NOT reflect actual usage. People get licensed for multiple modes, and generally only use one. And they have zero information regarding trunked system site organization, talkgroup IDs and their usage, or any of many other bits of data needed to properly scan a trunked system. They are useful for concentrating search and analysis efforts on a limited number of frequencies, rather than scanning entire bands. But that's it.
Gone camping.
Old 06-01-2018, 8:35 AM
W3JMC's Avatar
Understood and this only reinforces my point that although alternate sources exist, RR is the only viable one since it is user-submission maintained
John C.
Old 06-01-2018, 8:36 AM
n0nhp's Avatar
Years ago, I created and maintained a site with all the frequencies I could find for Western Colorado. It helped that I was working for a company that maintained the radios for a large part of the area but I would use information gathered when I traveled and from other users in the areas.
Just that information was always out of date, in need of maintenance or upgrading to be usable on new platforms.
RR came along and I gladly used my knowledge to keep their database up to date. I no longer worry about server crashes, upset communication managers threatening to take me to court for disclosing sensitive information (that was in public domain before I published it) or any of the other problems associated with the site.
Thanks Lindsay!
Bruce
N0NHP
Old 06-01-2018, 8:44 AM
W3JMC's Avatar
I remember about 10 to 15 years ago there was fordyce.org & Jim, the owner would post active frequencies for the New England / Mid-Atlantic area. Users could email submissions to him & he'd keep the database updated. He also ran a nice forum & I had a fun time moderating, keeping people in-line. Not sure what happened to Jim...
John C.
Old 06-01-2018, 12:00 PM
bob550's Avatar
If scanner owners were as plentiful as iPhone users, the Internet would be awash with hobby-related websites. You'd find scanners being sold in every Best Buy, Walmart, Target, and in any other number of retail stores. But, unfortunately, those of us that own scanners are in the minority, and that's reflected in the lack of resources.
Uniden BCD536HP, BCD996xt, BC890XLT, RS PRO-651, PRO-163, PRO-2006, PRO-93, Icom R5, R71A, Sony 2010; SDRPlay RSP2, RTL-SDR V3
Old 06-01-2018, 7:03 PM
dave3825's Avatar
I remember about 10 to 15 years ago there was fordyce.org . Not sure what happened to Jim...
At one point, many years ago, Jim's site was hacked Fordyce Site Hacked/No More - Scan New England
And more, https://forums.radioreference.com/443020-post1.html
If you go to Long Island Scanning Resources , the stuff is still there... The last site update was 2007.
And the Fordyce Family Archives are still up. Says the site is still maintained by Jim. I also thought I read on here that Jim was a member but I cant really remember ... Either way, the server is still running and someone is still paying for the domain name..
DMR436HP Br330T Pro 93 Pro 95
Arc330Pro ProScan Freescan BCDX36HP Easy Manual Id Tracker
Old 06-02-2018, 10:02 AM
Ensnared's Avatar
As I indicated, I just want a competitive alternative. I understand this is a monumental undertaking given the amount of data involved. I obtain a great deal of information from RR.
Yes, I used to have one of the original printouts from the TxWarn system from two great sources in Houston. There were pages and pages of documentation. I think it was called Starnet or something like that back then. No, you could not download anything with this list. But, it was rather extensive.
Old 06-03-2018, 6:01 AM
DaveNF2G's Avatar
Competition is not always a good thing. In a niche "market" like this one, the availability of multiple sources becomes a headache for the scanner user. It is hard enough getting people to submit updates to RRDB (rather than complain about inaccuracies). How can one infer that several such sites would receive better support? How many sites would be practical for downloading direct to a scanner or its support software? How many data formats would scanner manufacturers support and still provide free software (or even inexpensive software)?
These are rhetorical questions and are not intended to lengthen the thread.
David T. Stark
NF2G WQMY980 KYR7128
Old 06-03-2018, 6:05 AM
buddrousa's Avatar
#1 They are part of us.
#2 Why go anywhere but the best.
#3 We are the original
#4 We work together.
#5 Enough said.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx4 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
Old 06-03-2018, 6:42 AM
jonwienke's Avatar
We are the RadioReference.
Your frequency and system knowledge distinctiveness will be added to our own database.
Resistance is futile.
Gone camping.
Old 06-03-2018, 6:59 AM
Here is one alternative Intercept - Scanner Frequencies and Frequency Database
Their data for Texas and Oklahoma is mostly missing and what is there is as old as their web site.
Tom
Old 06-03-2018, 7:21 AM
iMONITOR's Avatar
Best Buy and Walmart do sell scanners.
Old 06-03-2018, 7:24 AM
jonwienke's Avatar
Wal-Mart doesn't sell scanners in their stores, only online.
Gone camping.
Old 06-03-2018, 7:30 AM
iMONITOR's Avatar
Thumbs up
Radio Reference is so much more than just a database. Lindsay his team, and RR members have worked very hard for many years to make it what is today! To have a one-stop-site for all things radio is awesome. It would be very difficult to duplicate let alone do it better.
Leadership Team
https://www.radioreference.com/apps/about/?a=team
