Old 07-03-2018, 2:35 AM
wbswetnam's Avatar
Default Solar-powered rechargers
There are times when, due to storms or other disruptions, that the power can be out for a considerable amount of time. I was visiting Washington DC in late July 2012 when a powerful derecho storm knocked out the power for four days. In anticipation of future events, recently I bought a 300000mAh dual USB portable solar battery charger on eBay for $14.00.
Would this be adequate to keep a low wattage scanner model such as the Uniden BCD325P2 charged up?
Too much of a good thing can be wonderful. - Mae West
Old 07-03-2018, 3:54 AM
buddrousa's Avatar
After reading the online specs 2 watt solar panel @ 5 volts the charging current is .4 amps (400 Mil) and it has a rechargeable battery and if the battery size is correct it would last about 20 times what your batteries in the scanner would last before running out of charge and would take weeks to recharge on solar power only.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
Old 07-03-2018, 6:49 AM
wbswetnam's Avatar
Obviously I need a higher wattage solar charging panel. Suggestions?
Old 07-03-2018, 6:51 AM
jonwienke's Avatar
I bought this foldable solar panel:
https://www.amazon.com/gp/product/B00RFCVR62/
It has a MPPT controller and will charge a USB power bank a lot faster than a 2-watt panel
Old 07-03-2018, 6:53 AM
jonwienke's Avatar
https://www.amazon.com/gp/product/B079LWP9MP/
I've tested this battery bank and it's storage rating is pretty accurate.
Old 07-03-2018, 8:15 AM
wbswetnam's Avatar
Thank you for the suggestions, Jon. They look like something to consider.
Old 07-03-2018, 11:16 AM
300 amp hours is a straight out lie. 300 Ah times 3.7 volts is 1110 watt hours. That's a battery that occupies about 300 cubic inches and weighs over 15 pounds, so get your ruler and bathroom scale out.
Here's a real 1200 Wh lithium ion battery: New Product: E-Scooter Portable Battery Pack - JTT Electronics Ltd.
If what you bought looks anything like these units Clive has reviewed, it's going to be garbage.
https://www.youtube.com/results?sear...lar+power+bank
Old 07-03-2018, 11:41 AM
wbswetnam's Avatar
I bought it from a seller on eBay, so it's got to be another A-number-1 top-shelf super-duper high quality product from China!
OK so I lost $14...
Old 07-03-2018, 12:34 PM
KK4JUG's Avatar
It may be an additional zero, intentional or otherwise.
If you can read this, thank a teacher. If you can read this in English, thank a vet.
Old 07-03-2018, 3:17 PM
wbswetnam's Avatar
My $14 'solar' USB charger arrived this afternoon... complete piece of junk. Very cheaply made, only vaguely resembles the product in the advertising photo.
Old 07-03-2018, 3:31 PM
DJ11DLN's Avatar
If there's a way to get a refund I'd go for it...14 bucks is 14 bucks. I haven't eBay'd anything in several years so I don't know.
But sometimes you just have to try something to see if it's any good. Sometimes you get nicked, and sometimes you wind up with a good value. I've had both happen many times and no doubt will have both happen many more times in the future.
If it looks stupid but it works...it ain't stupid.
Old 07-03-2018, 3:42 PM
jonwienke's Avatar
I'm not gay, but...
Old 07-12-2018, 2:49 AM
OK so I lost $14...
Are you able to share the link to where to get this?
Old 07-12-2018, 4:39 AM
krokus's Avatar
Did you see his next comment? (Quoted below)
Sent using Tapatalk
Old 07-12-2018, 4:50 AM
Sent using Tapatalk
Must have missed it sorry.
Sent from my SM-N950F using Tapatalk
