I recently purchased a 4 channel Motorola Radius that I plan on using as the radio for an internet feed for my local Railroad Line. Thanks to the wonderful help I received here I've since learned how to program and use it, and I've kept it with me in the car while I'm working to test it out as I don't yet have the antenna installed at my receive site. So far I've been VERY impressed with how much better this receives than my 2 scanners, and I've had zero intermod which happens quite a bit with either of my scanners and I pick up a lot more stuff.
So my question is, is there a receiver that can be programmed in the field without a PC, and that can hold at lest 20 channels without spending a fortune? I only want to receive, do not plan on transmitting.
Thanks for any suggestions.
Edit: I can't edit the subject line but I meant to say "Field programmable receiver"
