Old 02-01-2007, 7:08 PM
RadiationX's Avatar
Default What is VFO Scanning?
Does anyone know what this is, I look in the WIki and over the internet but im not quite sure what it is?
Old 02-01-2007, 7:17 PM
JESSERABBIT's Avatar
Where, and in what context did you hear about this? It may be something which is not related to scanners. Typically, a VFO (variable frequency osciallator) is a means by which the operator can change the operating frequency of a radio by turning a dial. (or by computer control)
Old 02-01-2007, 7:36 PM
Silent Key
years ago it was common to enter a frequency in the VFO and then hit a button that would scan up or down the band from the frequency you entered.
I have never found that criticism is ever inhibited by ignorance
Pimpala03's Avatar
It's probably where you can search through the VFO and find active frequencies. Search each consecutive frequency in a specific range (i.e. 155.000 - 161.0000) instead of only the ones you've input into your bank.
I lost my signature in Hurricane Katrina.
Old 02-01-2007, 7:43 PM
cristisphoto's Avatar
My AOR 8200 Mk3
Has that Feature
Not 100 percent sure if I have Used it to it full Capabilties...
Her ya all go
As per the 8200 Mk3 Man:
http://www.aorusa.com/Manual/ar82001.pdf
Crista
Hoo Ray Freedom !!!!
Old 02-01-2007, 7:57 PM
hotdjdave's Avatar
K9DJW - Senior Member
Default Variable-Frequency Oscillator
Here is an article on Variable-Frequency Oscillator (VFO) that explains it:
http://encyclopedia.thefreedictionar...ncy+Oscillator
Dave - K9DJW
Whence came you and whither are you traveling?
Old 02-01-2007, 8:15 PM
Cheers
Crista
Old 02-01-2007, 11:37 PM
k9rzz's Avatar
With the Icom R7000 or R7100, you can tune them like a regular general coverage receiver. Just turn the dial and search for sigs.
John K9RZZ
Old 02-02-2007, 12:03 AM
iMONITOR's Avatar
You can do that on several of the Uniden scanners as well! My BC796D's have VFO capability, as does several other Uniden models. It gives you the ability to manually tune through frequencies instead of preprogrammed channels.
