radio shack is the only place that i know of that you can walk in and then walk out with a new scanner. in my area no one sell's scanner but radio shack. i see a log of radio shack scanners on this forum and others. i know that uniden is good i have one that is twenty two years old never gave any trouble - bear cat 210 xl-. i was just wondering who had the best scanner now days ?MarkWestin said:In the last 2 years or so, I have bought the following:
Uniden BC246T, Uniden BCD396T, and Uniden BR330T.
If the BR330T had been available when I bought the BC246T, I would have bought it instead. It is much better all around than the BC246T. I'm thinking of selling my BC246T and buying a Uniden BCT15.
I also own and use four older Radio Shack (GRE) scanners, and several other receivers.
I had a PRO-95 that I bought new, but I sold it a few months later because I just didn't like it. That sort of soured me to Radio Shack products.
Today, a Uniden (or at least a Uniden built scanner) is the simple answer.jerry12 said:if you were going to get a new scanner what would you get a radioshack PrO- or UNIDEN ?
You're right about limitations with the Pro-96 series receivers. They won't do 700 MHz trunking or hybrid 700 and 800 MHz systems. 700 can only be received as a conventional channel, and only if the scanner has been "expanded" in software. I'm not sure what Radio Shack will do with marketing GRE equipment, or what will happen to GRE's distribution channels if Radio Shack tanks.loumaag said:The digital models (Pro-96/2096) are showing their age and have limitations. All of the newer major Uniden models have capabilities that exceed the GRE models and IMHO are easier to use and program (especially the dynamic memory units). I will look at GRE models when they introduce a new one, but at the present, they sadly lack what I need in a "today" scanner.
