Looking for the individual tones of pager code 1129 and 1192. Thanks!
OK so the two 1's mean that tone one is from group one as well as tone two?! I think I got it thanks!RBMTS said:Usually the 4 digit cap codes are using the Centracom coding method.
The "11" means that you use tone group 1. The "2" and the "9" are the tones numbers in that group. Therefore it should be:
1129 = 368.5 / 539.0
1192 = 539.0 / 368.5
Hope that works for you. Good luck!
bravo14 said:That will be correct about the info above. I ran 1129 1192 came up like that. If you need a tone recording I have a program that makes tones A and B.
bbreiler said:so if "11" means you would use tone group 1, what about "12"? I need to get the codes for QC on a 1261 system....
thank you
