kmacka
http://www.scannermaster.com/Pre_Amplifiers_s/45.htm
I was browsing around in the above link and was looking at picking up one of these pre-amps. I just have a question on these units. There are two different types of these pre-amps for air, which is the type I am looking for.
One of these gives this description:
Tuned low noise preamp. Range 118-137 MHz, gain typ. 20dB, BNC-connectors, supply 12V via coax.
The other ones gives this description:
Tuned low noise preamp, range 118-137 MHz, gain typ. 20dB, BNC-connectors, supply 12V via separate wire.
What is the difference between these two. Do these two pre-amps needs to be powered? One says supplied via separate wire the other says supplied via coax, what does this mean? Someone help, thanks! lol
