You haven't told us what frequency band your talking about. Many times there is
noise generated by the power lines from bad connections or insulators. Many
times when these connections or insulators get wet, the noise levels drop.
On low band, 30 to 50 MHz, this noise problem is much more noticable. As you
go higher in frequency, the power line noise issues seem to effect your reception less.
Another area of noise could be from an electric fence from a farm that has
cows or horses. They use the electric fence to keep the animals from getting
through their fences. These electric fences can produce a poping noise or
static for the duration of the pulse. This could be for maybe 1/2 s a second
or so. It gets worse if there is long grass getting into the fence wire.
Jim
tbharper said:
when it rains i get better signals everything comes in more clear here. the weaker signals are stronger and can pick up stuff i usally cant on a clear day. can anyone else tell a difference
