The FCC makes it suprisingly hard to find these codes, I discover, but they can be found in the instructions for filling out license applications for the desired services.
Here's the codes listed for Part 90 (Private Land Mobile) and Part 74 (Broadcast Relay)
Note: Where appropriate, follow each code with 'T' for Temporary, 'I' for Itinerant, 'S' for Standby, ‘A’ for Airport Terminal
Use, 'C' for Interconnect, 'J' for Temporary Interconnect, 'K' for Standby Interconnect, or 'L' for Itinerant Interconnect.
For example, FBT means Temporary Base. (NOTE: MO, MO3, MO6, MO7, MO8 & FXO use the alpha character “O”).
Base........................................................................................................................FB
Mobile Relay ...........................................................................................................FB2
Community Repeater .............................................................................................FB4
Private Carrier (Profit) ............................................................................................FB6
Private Carrier (Nonprofit) .......................................................................................FB7
Centralized Trunked Relay......................................................................................FB8
Control ...................................................................................................................FX1*
Mobile ....................................................................................................................MO
Mobile/Vehicular Repeater......................................................................................MO3
Private Carrier Mobile Operation (Profit) .................................................................MO6
Private Carrier Mobile Operation (Non-profit)..........................................................MO7
Centralized Trunked Mobile ....................................................................................MO8
Operational Fixed....................................................................................................FXO
Fixed Relay .............................................................................................................FX2
Fixed .......................................................................................................................FX**
Radiolocation Land .................................................................................................LR
Radiolocation Weather Radar .................................................................................WDX
Radiolocation Mobile...............................................................................................MR
Secondary Fixed Signaling .....................................................................................FX3
*Station associated with a mobile relay that employs the same frequency as the associated mobile station for control purposes.
**Station operating on frequencies available for fixed use for control purposes in accordance with applicable rules.
Additionally, here's the codes listed for Maritime and Aviation services:
For Maritime Service, select the station class code from the following table:
MC Service
Marine Utility………………………………………………………….FCU
Maritime Receiver Test……………………………………………...MRT
Maritime Support-Testing and Training……………………………FCA
Private Coast…………………………………………………………FCL
Public Coast…………………………………………………………..FC
Shore Radar Test …………………………………………………….MSC
Shore Radiolocation Test……………………………………………RLC
MK Service
Alaska Private ............................................................................APX
Alaska Public.............................................................................. APC
MR Service
Shore Radionavigation............................................................... MSR
Shore Radionavigation/RACON................................................. RLR
MA Service
Marine Operational Fixed...........................................................MFX
Note: Where appropriate, follow each code with 1 for Hand Held/Mobile operations or 2 for Temporary operations.
For Aviation Service, select the station class code from the following tables:
AF Service
Aeronautical Advisory ............................................................... (Unicom) FAA
Aeronautical Enroute.................................................................. FA
Aeronautical Fixed .....................................................................AX
Aeronautical Multicom................................................................ MFL
Aircraft (Flight Test Stations only) ..............................................FMA (must be followed by 1 for mobile operations)
Airport Control Tower ................................................................. FAC
Automatic Weather Observation ................................................ FAB
Aviation Support Instructional .................................................... FAS
Aviation Support Service............................................................ FLU
Flight Information Services......................................................... FIS
Flight Information Services with Hand Held/Mobile Operations . FIS1
Flight Information Services for Temporary Operations............... FIS2
Flight Test .................................................................................. FAT
Remote Communications Outlet ................................................ RCO
Ground Communications Outlet ................................................. GCO
Ramp Control .............................................................................RPC
AA Service
Aeronautical Search and Rescue............................................... SAR
Aeronautical Utility Mobile..........................................................MOU
Operational Fixed.......................................................................AOX
AR Service
Aeronautical Marker Beacon......................................................RLA
Aeronautical Radio Beacon........................................................RLB
Differential Global Positioning System (GPS) ............................ DGP
ELT Test .................................................................................... ELT
Glide Path (Slope)...................................................................... RLG
Localizer.....................................................................................RLL
Omnidirectional Radio Range .................................................... RLO
Radar/Radar Test....................................................................... RLD
Radionavigation Land ................................................................ RNV
Radionavigation Land Test ........................................................ RLT
Note: Where appropriate, follow each code with 1 for Mobile operations, 2 for Temporary operations, or (for flight test
stations only) 3 for Itinerant operations.
