MMIC said:...If a system is P-25, they will need to have 100% Motorola radios on the system to support the proprietary feature.
If it's a P25 control channel, won't the IDEN_UP messages take care of it? Wouldn't deviation from that part of the P25 'spec' make it a non-P25 system?MMIC said:On a related note, there is a feature that Motorola is selling called the "shuffled band plan". This will allow system owners to use a non-standard and/or customized channel plan assignment on their system. So frequency 851.xxxx may have a hex value of 100 on the control channel per the "standard" plan, but they have the option to change that to be another arbitrary number with the shuffled band plan.
The shuffled band plan option is not a standard implementation on systems after rebanding, but Motorola is making a run on selling it to go with rebanding since all subscribers will be touched anyway. If a system is P-25, they will need to have 100% Motorola radios on the system to support the proprietary feature.
car2back said:Didn't Micro$oft try something along the same lines a few years back? :wink: :lol:
DonS said:If it's a P25 control channel, won't the IDEN_UP messages take care of it? Wouldn't deviation from that part of the P25 'spec' make it a non-P25 system?
Extensions and enhancements, yes, but something that defeats another part of the P25 specification? (Presuming IDEN_UP is actually required by the P25 spec).N_Jay said:No, because the P25 specification is designed to allow extensions and enhancements.
DonS said:Extensions and enhancements, yes, but something that defeats another part of the P25 specification? (Presuming IDEN_UP is actually required by the P25 spec).
No attempt at humor was made.N_Jay said:If you would phrase your question without your poor attempt at humor it might be understandable enough to answer.DonS said:Extensions and enhancements, yes, but something that defeats another part of the P25 specification? (Presuming IDEN_UP is actually required by the P25 spec).
DonS said:No attempt at humor was made.
I'll rephrase, though:
Presumption 1: IDEN_UP with accurate information is required by the "P25 specification"
Presumption 2: Motorola plans on adding an "extension" or "enhancment" to their implementation of a P25 system, as permitted by the P25 specification.
Presumption 3: Motorola's extension/enhancment conflicts with the [presumed] required information in the IDEN_UP messages, based on the earlier post that said "If a system is P-25, they will need to have 100% Motorola radios on the system to support the proprietary feature" in regard to a "shuffled band plan".
Question: If all three presumptions are true, is a system with Motorola's extension/enhancement still a "P25 system", given that it no longer includes accurate information in the required IDEN_UP message?
I attempted to clarify that in my initial post (#7) on this thread, where I qualified my question with "If it's a P25 control channel". I was trying to determine what was meant by "P-25 system" in the statement "If a system is P-25, they will need to have 100% Motorola radios on the system to support the proprietary feature".N_Jay said:I am fairly sure that "shuffled band plan" is only on Motorola (3600) control channels.
I misread your reference to the IDEN_UP command as an "iDENed Up" (as in F-cked Up) command. Sorry
Since it is 3600 bps only it has no impact on P25 systems or standards.
This seems to be a common thread with them, coming up with nice, proprietary "enhancements" that rob the standardization and competitive procurement element of P25 - like their "wide pulse" mode or ADP encryption.MMIC said:(snip) If a system is P-25, they will need to have 100% M... radios on the system to support the proprietary feature.
902 said:This seems to be a common thread with them, coming up with nice, proprietary "enhancements" that rob the standardization and competitive procurement element of P25 - like their "wide pulse" mode or ADP encryption.
I understand the discussion predicated on a misconstrued statement. My comment is about meeting needs, which probably deserves its own thread, but I don't really intend on going further with it once I get this out -N_Jay said:Or offer products to market to meet the needs.
Glass 1/2 full or 1/2 empty?
EDIT: Just to be clear, this entire branch of the thread is based on a mistaken statement about the shuffled band plan feature.
