RedPenguin
- Joined
- Feb 28, 2007
- Messages
- 1,081
I was wonder if there is anything that I can do, so that my scanner and my switch will play nicely without having to buy a new switch.
I at this time can't really buy a new switch, but I want all my computers to run in 100MB mode so the network is not super slow and gets lock ups under normal use then when I am in 10MBs only.
See so far the only way to make the switch not screw up my scanners is to make every machine use 10 because at 100 the switch beings to radiate and just ruin almost all VHF-Lo, making me unable to listen to much of the fire departments in my area, they use the 33.xMHZ range, and it sometimes even ruins much higher freqs, like some 154.x MHZs.
See I think also, that my house must cause some problems, because if I use a RH77CA antenna, I don't really get that well of reception, I mean I can hear the police and EMS fine, but I have to laugh, because I have a wire wrapped around the frame of my window on the outside, that I had for shortwave, and when I put it on my scanner, many frequencies actually come in clearer, funny how in this case, a free piece of wire, gets better reception then a $20 antenna.
