ILikeHatchChili
- Joined
- Oct 2, 2005
- Messages
- 241
[I posted this thought in the NM Forum - I think it might do better here]
For what it's worth, I just got an idea for scanner manufacturers -- for scanner users like me.
I like to see a feature in the scanner which allows a transmission with a PL tone on to NOT be heard. That is, the station with the PL tone will deliberately mute the audio of the receiver, even though the station's carrier is detected by the receiver. --- just the opposite of what the PL should do.
For instance: I want to listen to the CSQ transmissions on 460.15 (from NMSP), and I do not want to listen to the Juarez station that transmits on 460.15 with a CTCSS of 107.3 Hz. I would put in a CTCSS of 107.3 Hz for the 460.15 channel, and choose the "L/O PL station" option when programming in the PL tone. The choice of this option allows me to listen to ALL 460.15 transmissions that do not have the PL of 107.3, -- meaning I can hear all transmissions with any other PL, and all stations without a PL (CSQ), but not the station with the PL of 107.3
Of course, I would still hear the intermods and crosstalks on 460.15 since I am essentially in the CSQ mode for the example above.
The default option when programming in the PL would be the way PL is currently used.
Can be done for DCS and CTCSS
What do you all think? Added flexibility worth having in a scanner? Call it "L/O PL", "Block PL", "xPL", or whatever,...... anything to distinguish from Channel L/O.
Peter
Peter
