Old 07-29-2007, 2:22 PM
Default trunking vs. digital trunking?
I'm looking for another scanner. Possibly a base scanner. I now have the PRO-67 and the PRO-96. I see scanners that say digital trunking and some just say triple trunking or something like that. What is the main difference between digital trunking and trunking.
Old 07-29-2007, 2:32 PM
standard/dual trunking moniters: edacs and motorola systems
triple trunking moniters: edacs, motorola, and LTR systems
digital trunking moniters: edacs, motorola, and project-25 system
where do you live? if your area has digital then you want a digital scanner.
i dont belive your pro-67 can pickup any trunking
your pro-96 on the other hand, can pick up just about anything out there today.
Old 07-29-2007, 3:56 PM
w0fg's Avatar
Trunking is a method of sharing frequencies to accomodate greater traffic. Digital (trunking or conventional) is a form of modulation, i.e. the way the signal is made to carry voice or other intelligence. One does not necessarily imply the other. Many scanners are capable of receiving trunked signals; only a few models are capable of receiving digital signals, trunked or otherwise. As you might expect, they are also the most expensive. Which you need depends on the systems in use in your area.
Rick
"The King has note of all that they intend, by interception which they dream not of. "
Henry V, Act ll, Scene 2.
Old 07-29-2007, 5:00 PM
Thanks for your information both of you. I am definitely in a P25 area. I live in Philadelphia and they switched over a few years ago. So I guess I need either the Pro-96 or the Pro-2096. Are there any other brands that offer Digital Trunking besides RadioShack? ANy brands and models off the top of your head?
Old 07-29-2007, 5:11 PM
Wiki Admin Emeritus
Uniden, and shortly, GRE (not marketed by RS this time) are both in the digital game. The GRE models are expected out this fall - check out the extensive forum threads on the subject. The following Wiki article indexes all the digital models;
http://wiki.radioreference.com/index...gital_Scanners
In addition to the Pa.forum. If you live in Philadelphia, you really need to belong to the Phillyscanner Yahoo group. It's a tremendous resource for that area, and there's an EBook to which you can subscribe which is, in some ways, even a better resource than the RRDB. Of course you can't download data from an EBook :.>>
73s Mike
Old 07-29-2007, 7:24 PM
hsdtech's Avatar
Why not just use your pro96? It's a digital scanner.
PRO-106, YAESU VX-5R, FT-2600M
ICOM 2000H, 706 MK11G
ALINC0 DJ X10
KENWOOD TS-2000
