kc4jgc said:
WOW! I hadn't realized that (or if I had I forgot
I have not made a big deal of it and a surprising number of people have not noticed the change.
kc4jgc said:
Obviously if you're at Sinclair there's no way you can attenuate Downtown since you're probably looking at it out your window.
I may be able to take advantage of the building itself to knock down some of the signal from the Downtown. There is a considerable amount of metal behind an antenna on the northwest corner. Mounting a couple of Yagi's on the mast that holds one of the STL dishes on that corner has possibilities for the Midtown.
The MMBT would involve some magic as I would be shooting over the Midtown.
The HRBT is not far offline from the Midtown, so there would be some magic there as well.
kc4jgc said:
You might have to do that as long as can use an unused data stream on the STL or a dedicated phone line. It'll be interesting what you and big bosses agree as to a solution and how it works out.
At first, I would probably end up using the existing POTS line to the transmitter site as it is rarely needed for other things, especially in morning drive. If I can prove the concept, maybe I can free up some other resources.
Most of the stations have been around for a long time and quite a bit of old equipment has accumulated. There may be something in the pile I can press into service.
Some of the sites have high speed internet, so that is a possibility.
The TSLs are pretty much at capacity already.
