anyone know if i can hook a rig blaster up to a kenwood th-d7. do i need any diffrewnt cables other then the ones it comes with. i was looking at the rigblaster plus
I'd check the Yahoo group for that radio (I'd be surprised if there isn't one...). However you are going into overkill - you can likely connect up with an opto isolator and a handful of parts (depending on what you are trying to do - which is missing from your message?)
What do the Rigblaster docs tell you? Why are you asking on a scanner forum instead of the Mighty Zed? I don't know but I hope that steers you in the right direction.
