I guess this is the most confusing part of your need. I don't know of any band that doesn't have some kind of communications in it. That is why Part 15 devices have such restrictions on them. If you are going to run any "power" at all, then what you are looking for doesn't exist.thrival said:...Still I'd rather not be in any of the communication bands.
thrival said:OK, I looked at those files and there's a lot to plow through. Could someone save
me some time and tell me what bands don't require a license? I just want to
use RF for power, not transmitting any content. I guess the HAMs and scanners
would call me 'noise.'
There are non-licensed bands all over the place, but most have pretty severe power restrictions.thrival said:OK, I looked at those files and there's a lot to plow through. Could someone save me some time and tell me what bands don't require a license? I just want to use RF for power, not transmitting any content. I guess the HAMs and scanners would call me 'noise.'
thrival said:First, I'm not looking for anyone to do my "work" for me, but I didn't think it 'work' for those more knowledgeable on the subject, to inform me of frequencies they know about, where a license isn't required.
I was thinking about 50 Mhz initially, but found the Radio Astronomy band just under 75 Mhz.
Point is to be somewhere w/sufficient power density and the traffic ain't, not cause too much noise earthside. Directional antennaes pointed up hopefully wouldn't be bothered.
Intent is to run a car, about 150 watts. Under the hood, could act like a faraday cage. Hey
if my idea works maybe the feds would give me my own slice ;( not likely, I know.)
thrival said:Intent is to run a car, about 150 watts. Under the hood, could act like a faraday cage. Hey
thrival said:Would a spark gap (as in, at the plugs) qualify as a dummy load?
I need to step up battery voltage through a transformer and the
only place I can dump to ground is the frame, which could make
me an unintentional radiator.
thrival said:Hi, I'm doing experiments, using RF energy. I was wondering what frequencies
are best to make noise on without disturbing anyone, between 100khz and 100MHZ?
Thanks!
