Is it possible to listen to Blue Tooth with a scanner? Or is Blue Tooth encrypted, i think its around 2.4ghz so i know the unidens wont do it but i guess AOR radio may?
The biggest use for Bluetooth is for wireless headsets on wireless phones.nec208 said:What is Blue Tooth use for?
Okay is it some Wifi?
Don_Burke said:The biggest use for Bluetooth is for wireless headsets on wireless phones.
Since it is a digital system, it can also be used for sending files (mainly photos) from phone to phone and phone to printer.
I have also seen Bluetooth wireless stereo headsets and Bluetooth set up as a wireless headset system for two-way radios of various types.
There is also a peer-to-peer mode which is pretty good for things like communications between people on a motorcycle.
While it does share some characteristics with 802.11g, it is quite a bit different.
Don_Burke said:802.11g is a spread spectrum system.
Bluetooth is a frequency hopping system.
I suppose it is possible that there might be a Bluetooth unit with some sort of maintenance mode that would let you monitor. It is also possible that a sufficiently competent hacker could reprogam a unit into a monitor. I have never heard of either of these things happening.
There must be test gear for Bluetooth, although I would guess we are talking about something north of 10K for a unit that would not really be all that interesting to listen to.
exkalibur said:Why would someone care to monitor Bluetooth anyway? Is the guy next to you on the bus so interesting that you need to listen to his phone calls?
I have seen ads for Bluetooth units that can run in a peer-to-peer mode. It looks like not all Bluetooth headsets have that mode. The ads mention nothing of a base.nec208 said:Do you not need a base? Like you have radio and I have a radio and we can talk if you have a bluetooth base?
Or if I have bluetooth phone and bluetooth base I can send photos from phone to phone if I have bluetooth base and both phones are bluetooth .
Mike_Oxlong said:N_Jay and others, this thread is about Bluetooth.
If you have something to add that's Bluetooth related, please do so.
If not, then don't post.
Pretty simple.
Don_Burke said:I have seen ads for Bluetooth units that can run in a peer-to-peer mode. It looks like not all Bluetooth headsets have that mode. The ads mention nothing of a base.
Back when I worked for the shack, we would play with the phones during slow periods. You can send pictures phone-to-phone and the receiving phone has the option of refusing the picture.
I did some reading about Bluetooth back then and found that there is quite a bit to the system that we are not seeing on the market. It would not surprise me to find out there is more to it by now.
The couple of links I came up with did not go into details about the software the computer is supposed to be running. In fact, I could not come up with anything beyond the mechanical construction of the "rifle."warrior420 said:A simple Google search for "Bluetooth Sniper rifle" will give you lots of fun stuff. Been around for years but i guess they are much stronger these days.
