I have a Yaesu 7800 and Larsen NMO 2/70B antenna, which is mounted on a trunk-lip NMO mount. I have the radio directly connected to the battery using 2 gauge positive cable and 8 gauge grounding cable, which is connected to where the jack is secured to the trunk body.
Heres my problem, I can receive signals great, better then I can with my 2096 scanner when listening to the same frequency. However whenever I transmit, no one seems to hear me, when I say a callsign others just keep on talking. Tonight for instance was a local NET meeting, and when they were taking visitors callsigns, no one gave any indication that they could hear my tranmission. The weird thing is, the SWR meter on my CB moves quite a bit when I transmit (the CB is off and isn't even connected to a power source).
So this has me wondering what the problem is. I made sure that the input frequency on which I transmit is correct, as well as the output, and I have the correct PL tone set. In this case it was 85.4Hz I believe, so I set it to "enc" on the radio, and I've tried it with repeaters with no PL without any luck.
So does this sound like it's because the antenna/mount arent getting a solid ground connection from the trunk, since both sides are painted? And if so, would sanding down the bottom side help? Or does it sound like the radio itself doesn't have a solid ground connection? BTW, should I be able to hear myself when I have my scanner tuned intot he output frequency of the repeater i'm transmitting on? Because I can only hear myself if I tune to the input frequency (which i'm talking on)
Any input is greatly appreciated!
