Hi again,
Still I can't resist nerdy Tech Wars just to confuse and/or bore the heck out of the jocks.
N-Jay, I don't need to properly use the quote feature, I don't use it at all and I won't, I won't, I WON'T! Such is the privelidge of the Grand Exalted Poobah of Radio (Reference) and if you try to make me I'll hold my breath until I turn blue.
Hmmm, eight layer vestigial sideband... so is it AM? No, it's USB with full carrier. Oh I'm sure you know the emission designator, you know everything. Since you do you recognize the similarity to analog NTSC VSB I'm sure inasmuch as only the type of modulation has changed. Well, if nothing else they no longer use two transmitters and a combiner.
Clam, now that I've thrown rocks at N_Jay I'll let you argue with him, it should be fun reading.
I can see the point in using tilt, slant, slope or whatever even with a scanner but still it only makes a difference in long cable runs. I saw a real problem when I moved into this building, the landlord had a Frankenstein cable setup with a plethora of splitters here and there and long runs, quite a mess. The VHF Lo Band signals were bad enough but when it got into Hyper Band it was like watching a white goose in a blizzard. Recently he installed a proper DA with individual cable runs, what a difference!
"Well, if you understood the issues involved you would understand why noise figure is as, if not more important than gain.
(Seems like another case of someone not "understanding" everything they "know"!)"
Once again N_Jay is right, regardless of the application noise is noise. I went off on the TV tangent just to make that point, a strong signal is still crap if it's full of noise. Anyone with an on line computer should know that, line noise causes a high BER resulting in excessive resends and slows down the internet connection. Then there's BPL and what radio signals do to it, interference works both ways. (evil grin with horns) Before I go off again let me remind you the same thing happens to DTV, there's lots of things that all come down to noise interrupting the data stream that causes pixelization, halting, and in a worst case scenario the dreaded blue screen when the buffer empties.
"Certainly the amp someone would pick for digital TV is not the same as the amp best for (analog) scanning."
N-Jay is being uncharacteristically kind. I being reminded of the snake oil "HDTV antennas" would rake you over the coals for being patently ridiculous, an amp is an amp is an amp. Well, maybe I just did so I'm sorry but please stop and think a minute. What's the difference between digital TV and analog scanning? Oh don't say video or I'll shoot you where it hurts! (;->)
OK, enough of that, this is SUPPOSED to be a scanner forum but I'll leave you with the thought for today. N_Jay is like a juice commercial on TV with that slap upside the head bit, "Gee, I could have had a V-8!"
INCOMING!!!
