pl's
captclint
Mentor
Mountaintop, PA
Don_Burke said:
If your scanner supports it, you can search for PLs. That is how I find most of mine.
For example, the your (godskidz's) 246 allows you to chose: search in the PL choice. It displays the PL almost instantly, vs my 796 that takes several seconds.
Harryjr
Southeastern CT
Without a PL search feature, you'll need to get a list of PL tones. Then enter the frequency numerous times, first without any PL, then each subsequent time with a different PL. See which one pops up active to match the agency you are seeking.
It's a pain, but worth it if you're getting a lot of interference.
HarryJr
captclint
Mentor
Mountaintop, PA
godskidz said:
Where do I get a list of pl's?
Based on the list of scanners in your signature, you have more than one that will search for PL's. There is no need to try one at a time. BTW, your own 246T has a list of PL's, Just rotate the menu knob when you are in the PL field.
