CLTX11 said:
8,000smp rate
8 bit stereo
Data compressed
Squelch delay at 1000
and my squelch is set at 9%
I hope you don't mind my jumping in here.
All those items you have listed seem to be the defaults except your squelch level of 9%
Mine is set at 5% and works OK.
Because the final .WAV files are so large, I tried GSM 6.10 8,000 kHz, Mono 1kb/sec.
It seems to sound OK and the file size is much smaller. 2 Sec. used 2MB of disk space at the default setting. With the GSM 6.10 setting (whatever that means), 2 sec. used only 0.24 MB and it sounds fine. It's only voice so quality is not very important.
But I have to set it every time. Do you know how to change the default settings?
I can't find any info. about these and other settings and what they do.
Thanks,
Dick
