Yeah, for receiving it's not a big issue. The number of adapters could attenuate the signal slightly, but it's so minor for receiving that I wouldn't be concerned.
Transmitting is a different story, 90's should not be used in a transmitting line unless there is not another option. They create impedance humps in the line and develop hot spots.
Adapters, unless properly designed will do the same thing. A good adapter will taper from one internal diameter to the other smoothly and the center conductor will do the same.
This has to do with the impedance of the cable line. If you compare 50 and 75 ohm cables of similar outside diameters the center conductor is smaller in the 75 ohm cable. Adapters are no different. Granted, you would need a TDR to see the hump in the impedance of a cable with a poor design adapter on it, but it's still there.
I know it's a bit complex to understand but I hope the info helps.
