I have a 796D which has record-out jack as well as a speaker jack.
I also have a tape recorder with a PTT type switch that turns on the recorder.
To record radio transmissions from the tape-out jack I know that the 'rec' function must be enabled for the bank/channel/tg, whatever.
How do I enable the recorder (using PTT) only when traffic is received? I do not desire to use a voice activated switch to turn on the recorder, only record traffic on specific channels and not have dead space on my tape. As is supposed to be, audio is only sent to the recorder when on a 'rec' channel but the tape is running all the time.
Thanks,
Rick
Thanks,
Rick
