trixwagen
What exactly is "front end", when referring to a scanner?
I've never heard that an antenna is part of a front end. The front end is the FIRST stage of a receiver, the electronics portion.n2mdk said:To keep this simple the front end is really the antenna and first stage of signal detection and amplification.
kb2vxa said:No, just the RF amplifier and first mixer stage. The RF amp is the first active stage so you must be thinking of the first IF amplifier, they're all active stages all the way to the loudspeaker. You're confusing stages with components, some of those are active (transistors) while others are passive (resistors, capacitors, etc.).
Pretty good for just a guess, you're learning.
gmclam said:I've never heard that an antenna is part of a front end. The front end is the FIRST stage of a receiver, the electronics portion.
