Being nosy, I asked for and received a trunking scanner for Christmas. I thought you plugged it in and suddenly you knew it all.
It is a Radio Shack PRO-528 1000 channel handheld trunking scanner. There seems to be no rhyme or reason to what I pick up.
I want to be armed with the frequency numbers when I finally find someone to program them in. I can'y figure it out. I don't know where to go to find these.
I live in Maine, Piscataquis county.......want other areas as well.
I receive at times, off and on...airlines and life flight.....police an hour away as well as two hours away. got some on ham once..actually receive little from the local police.
It says it is desiged to tract motorolla type 1, type2, hybrid analog systems such as smartnet and privacy plus ...plus, m/a-com edacs and ef johnson ltr
I have outside antenae but it is inside still....vhf-hi/uhf..outdoor scanner antenna 108-1300mhz range..about 20" height it says.
what am i working with here and how do i make it work and where do i get a list of frequencys and codes???
Help!!! Thanks
Help!!! Thanks
