| General Scanning Forum General forum for the discussion of radio communications related information, including discussion regarding scanners and radio receivers. Location specific posts should be directed to the regional forums listed below. |
03-29-2008, 07:58 PM
Determining frequencies used by unknown RF device
I have a device, thread like. Less than a millimeter in diameter, likely no more than an inch long. Very little metal in it.
It amounts to a sophisticated two-way way radio, inductively powered, like a crystal radio. This device is apparently designed to be dumped into a persons Maxillary sinus, one (conveniently) located next to each eardrum. Once in there all sorts of shenanigans can be played.
I need to determine the frequencies this device uses. How would one go about this? On top of this I don't know what sort of modulation/encoding scheme is being used. I was thinking about trying to design some simple circuits that would generate broadband noise and refine things from there.
Any suggestions?
03-29-2008, 08:07 PM
This sounds dubious!
but to answer your question, a frequency counter or a scanner with a near-field detector (close call/signal stalker etc) feature.
as far as modulation, i'm thinking FM.
GRE PSR-300
Uniden SC150B
Sony ICF-7600GR
Sony ICF-S10Mk2
03-29-2008, 09:07 PM
With a scanner that has close call or signal stalker, or a frequency counter if it's out of the scanners range.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
03-29-2008, 09:56 PM
Skip the frequency counter
Any suggestions?
Don't think the freq counter will work here. Here's how I would surmise it works:
An external device induces a current field into it to read the device. So it won't be generating any rf until a LC circuit in it it gets charged by the reader.
03-30-2008, 02:10 AM
If you have the technical skills to do circuit design, you have the skills to determine the frequency it operates on. What is the point of this trolling exercise?
12 volt radios are for wimps. Real radios can kill you.
03-30-2008, 10:05 AM
Ask the aliens in the mothership to show you their galactic license for the device.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
03-30-2008, 10:10 AM
Block all the signals with a tinfoil hat.
03-30-2008, 10:28 AM
I find the those tin foil BBQ bags work best. You can also make copper coils and stick them in all your oriffices that should block all the signals, but you have to make sure that you put them in all your oriffices.
03-30-2008, 11:33 AM
If you're serious, the only way I can think of is to use a sweep generator to provide the activation signal and a spectrum analyzer to look for outputs. You might be able to figure out the modulation by looking at the output spectrum.
Take a look at <<http://en.wikipedia.org/wiki/RFID>>
As you'll see at:
<<http://www.rfid-handbook.de/rfid/frequencies.html>>
There are a wide variety of frequency ranges in use, although I'd start looking at the higher ranges first.
Northe
N6KO
Green Valley AZ
03-30-2008, 09:44 PM
Thanks for the replies
Given the dimensions of this thing it's something in the microwave range. It's unbelievable. It's both incredibly amazing and nasty. It amounts to an inductively powered cell phone. It's just hard to believe how small they can make these things. What's sad is something that was obviously developed by the state is now being used 'play' and destroy people for no other reason than it's fun and very profitable.
I just don't have the resources to pursue this.
03-30-2008, 11:01 PM
so if you put one of these devices up your but, could someone make you sh!t your pants by remote control?
dont laugh, it is a serious question.
GRE PSR-300
Uniden SC150B
Sony ICF-7600GR
Sony ICF-S10Mk2
03-30-2008, 11:40 PM
Did you know you spelled but wrong? You meant BUTT didn't you?
Now back to work. If you no work you fired !!!
03-31-2008, 12:28 PM
First of all we have to know if this thing is a transmitter with the CIA spying on you, a receiver of voices in your head disguised as a dog named Sam telling you to shoot people with a .44 Magnum or a transceiver the aliens use to turn you into a mindless automaton doing their bidding. Until this has been determined I can't give you specific instructions but meanwhile I suggest you shove it in your behind and eat plenty of beans, that'll confuse 'em.
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
03-31-2008, 12:53 PM
HMMM,
Microwave range, inside your head.
Would'nt your brain cells go Orville Redenbacher on you?
Livin' in the hills, mountain top dx'n.
Welcome to come up...if you're invited.
All others will be shot.
03-31-2008, 01:24 PM
OH/WV DB Admin
If this would work, there are a lot of people on these forums that really have a need for it
03-31-2008, 01:40 PM
How well I know, I poop every day and I'm STILL full of it!
"Wouldn't your brain cells go Orville Redenbacher on you?"
Nah, Harlan Sanders has already been there.
OBEY
73 de Warren
04-01-2008, 11:30 AM
More info needed
And your response has some errors in it as well!!! You mean "... you're fired...".
Yeah, since higher frequencies have a smaller wavelength, it would make more sense. I agree with the idea that it is probably powered by external RF inductance. It actually sounds a lot like a larger scale RFID device. The application could range from the device transmitting back a fixed digital code to audio; or perhaps it is just a receiver. To help you out any further you need to supply us with a lot more information, and some pictures. Where did you get this thing?
PRO-95 | (customized) PRO-10 | PRO-97 | PRO-77 (customized) | PRO-92 | PSR-300
11-05-2009, 11:12 AM
[QUOTE=gmclam;763291 Where did you get this thing?[/QUOTE]
Don't you mean ... When did you dream this thing?
11-05-2009, 12:02 PM
I'd say buy your post count you should stick it in the microwave at you local minimart, or hit it with a hammer. Both of which should only be done after re-inserting it into your head.
BCT7, PRO97<-was run over, PRO164<-to replace the 97, BCT15 w/ GPS, PRO160, PRO2096
And various other electronic toys blah blah blah blah blah
11-05-2009, 12:22 PM
I think that additional resources are required at this time:
Additional Resources
Does anyone have George Noory's pager number?
(Oh great, I just wasted my 100th post on THIS!)
