Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > General Scanning Forum
General Scanning Forum General forum for the discussion of radio communications related information, including discussion regarding scanners and radio receivers. Location specific posts should be directed to the regional forums listed below.
Old 05-17-2008, 09:40 PM
Default Any recievers that handle both HF and Scanner frequencies?
I have a RS Pro-97, but I am thinking of returning it to get an HF receiver and wondering if any also handle scanner frequencies? It would be nice to have one unit for everything.
Thaellar
Old 05-17-2008, 09:47 PM
I think the Yaesu VX-3R can handle HF and scanner frequencies. I could be wrong though
Old 05-17-2008, 10:08 PM
n2mdk's Avatar
Yes there are plenty of wideband receivers available, thing is unless your will to spend quite a lot of money the radios tend to be compromises at best. I have a BR330T it covers 100 kHz - 1.3 GHz but really wouldn't consider using to down on the HF bands. If I want to listen to SW/HF I'll use my Grundig Satellit 700.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Old 05-17-2008, 10:10 PM
snjct2000's Avatar
Yupiteru MVT-9000 and MVT-7100 available from Bandercom.com
Old 05-17-2008, 10:11 PM
Sounding like jack of all trades applies here. That's okay. Nothing wrong with specialization. Just curious if there was something that did an excellent job on both.
cheers,
Thaellar
Old 05-17-2008, 10:13 PM
R1VINCE's Avatar
also consider an AOR AR8200 or AR8000 or Uniden BR330T
not the greatest HF recievers but they do recieve HF-
AR8200MIII/AR8000/BC2500XLT/BR330T/BCT15w/GPS/BC780XLTx3/BCD996T/RH-96/PRO2006x2/PRO2004/PRO92/VX-5S/D130JN/IC-R70
Old 05-17-2008, 11:09 PM
Raven95150's Avatar
There's also the Alinco DJ-X3. It covers 0.1 - 1300 mhz and you can get one for around $100.
KD0AXS
Metro Skywarn #7344
Uniden BCD396T, BC250D, BC350A
RS PRO-84
Yaesu FT-2800M, VX-170
Old 05-18-2008, 12:05 AM
If you want a portable, the Yaesu VX-2R is hard to beat for the price. It is the discontinued cousin of the VX-3R but I think it's a better performer. You can often find it on e-bay for $75 or less. It covers HF well with a good antenna and scanner frequencies very well with a replacement antenna like the Diamond RH-77CA. You're also set with a dual band ham radio if you want to get your ham license.
Regards, Jim
Old 05-18-2008, 10:40 AM
Icom R-20 gets it.
Old 05-18-2008, 12:59 PM
The AOR-8200MK3/ICOM-R20 do an excellent on hf/vhf/uhf and they are wideband receivers with no trunking.
Regards Lino.
ALINCO-DJX2000
2 AOR-3000A/AOR-8200MK3
ETON-E5 HF PORTABLE
GRE-PSR500
ICOM=R3/ICOM-R5/ICOM-R20/ICOM-PCR1000/ICOM-PCR1500/ICOM-R2500/ICOM-R9500/ICOM-92AD
JRC NRD-545
RADIO SHACK-PRO2035
REALISTIC-PRO2035
UNIDEN-245/UNIDEN-396/UNIDEN-780/UNIDEN-996
YAESU-VX7R/YAESU-FT8800R/YAESU-VR500/YAESU-VR5000
Old 05-18-2008, 06:33 PM
W4KRR's Avatar
The Uniden BR330T is the only wideband receiver that also does trunking, AFAIK. All of the other wideband receivers mentioned above won't trunk track, which may or may not be an issue for you, depending on what you want to monitor. A hand held wideband receiver is a compromise on the HF bands compared to a dedicated tabletop HF receiver and a good outside HF antenna. JMO.
Ken
Similar Threads
Pro 2035 For sale Quint6 Old Classifieds Archives 3 09-02-2007 08:34 PM
WTB:Or Swap HF Rig , For BC-796D Scanner wc8i Old Classifieds Archives 0 04-26-2007 03:07 PM
new to HF shores HF/MW/LW General Discussion 19 07-02-2006 01:20 AM
Icom R-75 as an HF "scanner" Scanner-geek ICOM Receivers 2 06-10-2006 03:21 PM
