Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > General Scanning Forum
General Scanning Forum General forum for the discussion of radio communications related information, including discussion regarding scanners and radio receivers. Location specific posts should be directed to the regional forums listed below.
Old 07-27-2008, 07:14 PM
btritch's Avatar
Send a message via MSN to btritch Send a message via Yahoo to btritch
Post Rolling Code Inversion On PD Frequency..
There's a frequency here in Arkansas in one of the counties, It's a sheriff's department in Izard County, Now it says in the DB that they use "ROLLING CODE INVERSION" on all of thier conversations and transmissions, However, I heard this department from Paragould Arkansas Earlier in the day which is three counties over and heard every word, It wasn't scrambled at all... Rolling code inversion does mean scrambled conversation right? If so, Why could I Hear it, Why was it not scrambled? Can anyone explain?
Brian
Paragould/Greene County Arkansas 72450
Online Area Scanner Feed: http://greene.ar.scanamerica.us/
Old 07-27-2008, 07:17 PM
brandon's Avatar
It's possible they stopped using it and the database had not been updated yet.
Old 07-27-2008, 07:19 PM
btritch's Avatar
That's true, That had crossed my mind, I caught them bleeding over on one my local channels while mobile this afternoon, I'm going to enter them here and listen, I should be able to get them...And confirm and update DB if necessary.. I thought Rolling Code Inversion meant scrambled... Thanks..
Brian
Old 07-27-2008, 07:25 PM
Send a message via AIM to fineshot1
I am sure they do not use it all the time. They probably have it programed into there radios so they can use it only when called for - another words all they probably need to do is hit a button or switch and they are in scramble mode. Just an educated guess...
fineshot1
NJ USA
Old 07-27-2008, 07:27 PM
btritch's Avatar
That's what I was thinking... I'm going to monitor and see..
Brian
Old 07-27-2008, 07:34 PM
Here's one link with a little info.
http://www.policeone.com/police-prod...ical-Overview/
And a company who sells many boards for various radios.
http://www.midians.com/html/products...ice+Scramblers
Old 07-27-2008, 08:30 PM
not trying to highjack this post, but there are times when i was living in buffalo, and the pd would be doing their normal dispatching and then a unit would cut in with encryption and transmit, but no one say's anything back to that unit and the dispatcher doesn't recognize that the unit is transmitting.
Could that be a Data transmission?
Old 07-27-2008, 08:45 PM
It could be, but if it was data how would you be sure it was encrypted or just unencrypted data.
Also, there are many times a unit could say something that does not need any reply.
Similar Threads
Unidentified Talkgroups in the Richmond, Henrico, Chesterfield System Stick0413 Virginia Radio Discussion Forum 13 05-19-2009 06:22 PM
Vacationing in Uncasville, what to listen to? UFEMTFF Connecticut Radio Discussion Forum 10 07-03-2007 02:32 PM
2007/06/30 VHF Low Band kkn50 Skip / Tropospheric Ducting Forum 0 07-01-2007 01:52 PM
FS: RS DSP40 w/ frequency inversion decoder EBAY now Audiodave1 Old Classifieds Archives 4 05-01-2005 10:21 PM
Got this from my Union page might be of intrest to someone!! Stumper426 General Scanning Forum 1 06-22-2004 07:49 PM
