Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > General Scanning Forum
General Scanning Forum General forum for the discussion of radio communications related information, including discussion regarding scanners and radio receivers. Location specific posts should be directed to the regional forums listed below.
Old 08-19-2008, 05:30 PM
Question Using scanner to monitor VHF marine radio traffic
I use a scanner (Uniden Sportcat 180) to monitor marine radio traffic on the Chesapeake Bay. But when I park it on the table beside a dedicated marine VHF handheld radio, I notice that the VHF receives all the normal traffic and the scanner misses some of it. And the traffic that the scanner does pick up is not nearly as clear as what comes through the VHF radio (for both near and distant signals).
I would much prefer to use the scanner so I could listen to nearby EMS and police activity too. But the sound quality in the handheld VHF is far superior so I tend to listen to that more.
Is this just a sensitivity issue on the SC 180? If so, is there a better scanner that might be more sensitive, like a PRO-97? Or am I better off just finding another VHF radio that can scan between several pre-set channels ?
Old 08-19-2008, 05:56 PM
commercial ht-band specific and commercial grade component's.a commercial grade ht is alway's going to win in the sensitivity dept.their speaker's are generally better than a scanner's too.yes,if you have the buck's to spend get a commercial grade radio.keep the scanner for "on the fly" monitoring.commercial radio's have their drawback's.most of them don't make it easy to change frequencies.they usually are not multi band either.a good compromise might be a ham ht.do a little research.just my 2 cent's.out of all of them i seem to like yaesu's the best.
Old 08-19-2008, 10:15 PM
MrRevesz's Avatar
Send a message via AIM to MrRevesz Send a message via MSN to MrRevesz
Could it have anything to do with the antenna? Maybe you need one more specific for the Marine band?
BCT-15, BC246T, BC92XLT, Icom IC-V8, Radioshack Pro-2025, Radioshack Pro-94, Motorola Spectra A4 UHF, Icom IC-F80 soon to be upgraded to digital!
Old 08-19-2008, 10:53 PM
cpuerror's Avatar
Its probably the antenna. The stock black bearcat antennas do work if you climb up the transmitter tower and make sure the scanner antenna is touching the transmitter antenna, and that transmitter is a minimum of 500w, but for greater range and/or less powerful transmitters I would recommend replacing it.
http://scannow.org - Download FreeSCAN
Old 08-20-2008, 10:14 AM
So I should consider something like an Austin Condor or one of the extendable antennas from Radio Shack? I have a hard time believing the antenna would be the issue since the stock 8" antenna is pulling in the signal on the VHF radio so well....
Old 08-20-2008, 11:50 AM
N8IAA's Avatar
Band specific radios will always outperform a widebanded radio as mentioned above. Audio on scanners has always been a sore point with those of us that use them. By the way, the PD, FD, and other systems you want to listen to are on the VA STARS P-25 digital system. You will need one of the newer digital scanners to listen to those frequencies. For any of my VHF listening, I use a Yaesu VX-170 2m HT, my IC-2720, or by Yaesu FT-1500. Big difference in receive and audio than a scanner.
Larry
Old 08-21-2008, 09:33 PM
Twister_2's Avatar
Send a message via AIM to Twister_2 Send a message via Yahoo to Twister_2
I don't live near the oceans...so I don't receive the maritime tx's. I just wanted to know what all you hear....such as distress calls (in any), coast guard, or just radio checks. How interesting is it?
73
KB3RRV
_______________
TS-130SE TM-261 VX-170 VX-3R Pro-2050 Pro-106 and more
Similar Threads
Uniden BCD396T Price/taking orders rankin6 Uniden Scanners 3 09-09-2009 08:20 AM
Southern NV Radio Scanner Book April 2007 Review Part II TOUGHLIFE Nevada Radio Discussion Forum 2 05-05-2007 04:45 AM
When Did Trunktrackers Become Legal To Manufacture? JohnnyGalaga General Scanning Forum 26 06-03-2006 09:36 PM
New Edition of Southern NV Scanner Book: An Evaluation Part I of II TOUGHLIFE Nevada Radio Discussion Forum 7 05-27-2006 12:56 PM
RadioShack Closing 400-700 Stores antfreq Tavern Archives 28 02-25-2006 09:13 PM
