Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > General Scanning Forum
General Scanning Forum General forum for the discussion of radio communications related information, including discussion regarding scanners and radio receivers. Location specific posts should be directed to the regional forums listed below.
Old 02-10-2009, 02:22 PM
Default Radio System for Farm Use
So a friend who is a farmer was asking me what to do, he has poor cell coverage of his farm and would like to have a radio system for communication between himself and his wife. He would like some sort of hand held, and has experimented with FRS. The FRS does not have the coverage he needs. And CB is not as portable as needed. The only thing I could think of to reccomend would be GMRS. I know that a licence is required, but not much beyond that. HAM is out, because they think it would be too complicated. So I am looking for suggestions as to what every one would reccomend. I think the prefrence is for hand held radios that can reach about four miles over variable terrain...any suggestions and where to pick up some used equipment would be greatly appreciated.
Old 02-10-2009, 02:25 PM
N_Jay's Avatar
His farm is a business, just get a license and a proper system.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 02-10-2009, 02:31 PM
DDan's Avatar
That sounds good but the expense for getting a freq. assigned is prohibitive in this case. I don't remember where I got this number so correct me if I'm wrong, I think it can cost well over $5000.
GMRS sounds like the best bet. If more radios were available, MURS might work as well.
73 de Dan/w6kru
Yaesu FT-857 FT-90 VX-170 VX-3
BCD396XT BCD396T PRO-90 PRO-2050
Base RS 20-176 / Maxrad MFB8133 & MYA8256
Mobile Maxrad MUF8043
http://dansracephotos.com
Old 02-10-2009, 02:41 PM
Well, the farm is not what I would call a real business...this farmer is more like semi retired. That is why I was trying to find an inexpensive option. These people are getting up in the years and so quick access to the land line could be a life saver.
Old 02-10-2009, 02:52 PM
N_Jay's Avatar
Then get a GMRS license and cheap repeater.
Old 02-10-2009, 03:08 PM
Steveradio's Avatar
I had a 10watt repeater set up for my Grandfather to use during farm time since mostly all valleys we worked in and a neighbor farmer used the repeater as well with a 100 acre farm. We switched to just simplex since we did not have a lot of miles to cover and the other farmer switched to Nextel (go figure).
Simplex operations work depending on the terrine and how much they need to talk. Check e-bay for a mobile radio for the farm equipment or maybe a used HT1000 with simple operation and "shh" since its just the two of them use itinerant or MURS frequencies so you don't need to worry about a license.
Steve
http://lvcomm.proboards33.com/index.cgi
Scanning Lehigh Valley, Pa. North of Philadelphia
Old 02-10-2009, 03:21 PM
N_Jay's Avatar
Portable to portable may be all he needs, but a repeater is nice to have and even an antenna at roof level will make a GREAT improvement in range.
You probably want a base at the house or barn anyhow, so the added cost is minimal.
Old 02-10-2009, 03:45 PM
PHOENIX_SCANNER's Avatar
Sounds like GMRS with a repeater to me. A family farm is exactly the type of thing GMRS is meant for.
PRO-106, BCD966T
WQGA468 - GMRS - Midland 45 watt base - Icom portables
Past:
Pro-14, 2022, 2023, 2024, 2033, 2006, 39, 43, 2096, 96, 197, 162, UBC9000XLT, BCT15, 396, PSR-400,500,600
Old 02-10-2009, 04:25 PM
If its a family farm then GMRS is a great option. If any of the farm hands and radio users are not family GMRS is out. As for $5000 for a frequencies thats way off, Should be more than a few hundred dollars.
Old 02-10-2009, 04:59 PM
Don`t know how good the coverage would be, or the affordability thing here, but what of getting a couple of Nextel units? Those work swell (i and a Ham friend use those to chat between here and his home downstate in WI). Another advantage would be that those can`t be monitored, not sure whether that`s even an issue (in today`s world i could see that being a bit of one IMHO). Just a suggestion. N9NRA
Old 02-10-2009, 05:48 PM
K8TEK's Avatar
Send a message via AIM to K8TEK Send a message via Yahoo to K8TEK Send a message via Skype™ to K8TEK
You are going to need a 6 site P25 system for proper communications. Talk to your local Motorola dealer and tell them you are interested in installing a multi-site P25 system. They can provide you with the details.
RIM 9630|Motorola E815|Samsung SCH-U740|Motorola T730|Motorola i355|A girlfriend|Motorola V120c|Kenwood DPX501|
MURS or GMRS. MURS does not require a license. GMRS does, but there are some options for putting up a repeater. I recently bought four MURS capable handheld radios, including extra batteries, for $45 on Ebay. It doesn't get any cheaper than that.
Old 02-10-2009, 06:14 PM
Send a message via AIM to KS4VT
You are way off. I licensed a repeater pair and talk-around for my HOA about 2 years ago and it was approximately $400.
I would vote for MURS as he could utilize an antenna with some elevation, if a repeated system is out of the question. But the issue with MURS is that someone needs to be by the base radio to communicate. There is no guarantee that 2 VHF portables at ground level will go the 4 mile distance without a repeater.
I put a low power (20 watt) repeater for my HOA with the antenna at around 35 or 40' and the staff can communicate via thier 4 watt portables for more than 6 miles around the community to include the local strip malls where there is a Lowes and Home Depot. They will never go back to a non-licensed service again.
Old 02-10-2009, 06:19 PM
DDan's Avatar
Originally Posted by KS4VT View Post
You are way off. I licensed a repeater pair and talk-around for my HOA and it was approximately $400.
Yep. I don't remember where I got that number. Someone pointed out my error earlier.
73 de Dan/w6kru
Old 02-10-2009, 06:26 PM
I'm surprised that the "police' didn't say this yet....
The legal power for MURS HT's is 2 watts. With a $75 or so GMRS license you can have up to 5 watts and up to 50 watts in a mobile. All depends on your budget I suppose. 4 miles might be pushing it a little bit with some trees/hills and a stock duckie antenna. Depends on the terrain, you could probably get a nice 7 inch or so performance antenna online
Old 02-10-2009, 06:29 PM
pliquett's Avatar
I've heard that the "new" Nextels, post Sprint, will work unit to unit up to 10 miles without cell signal. There is a Sprint/Nextel store about every 2 miles in the city, wouldn't hurt to ask.
Old 02-10-2009, 06:45 PM
N_Jay's Avatar
Maybe because no one was saying things that made it necessary?
Just a thought.
Old 02-10-2009, 06:54 PM
N_Jay's Avatar
I would tend not to believe it.
Old 02-10-2009, 07:13 PM
DDan's Avatar
Hey Jay, can I pick the spot for the test?
73 de Dan/w6kru
Old 02-10-2009, 07:25 PM
N_Jay's Avatar
So could I.
However, knowing what they sell now, and the range of possibilities of what the "might" sell, I figure if you don't get 10 miles now, you are not getting it any time soon.
Similar Threads
Darwin Cove Convention Centre grant Australia Radio Discussion Forums 8 10-31-2008 04:51 AM
$4M radio system a 'paperweight' Thunderbolt Community Announcements and News 18 02-22-2008 01:23 PM
Radio System troubles exkalibur Trunking Forum 33 11-05-2007 07:18 AM
State Radio System n4voxgill South Dakota Radio Discussion Forum 3 03-03-2005 10:13 AM
Nevada Statewide Radio System - News and discoveries Pro-95 Nevada Radio Discussion Forum 6 08-06-2004 05:09 PM
