Hi
anthorg welcome to RadioReference
Is this the county you want to program?
http://www.radioreference.com/apps/db/?sid=287 and
http://www.radioreference.com/apps/db/?ctid=1899
The easiest way will require a little "prep" work by purchasing some programming software and also a premium membership here at RR that will work in conjuntion with the software. The other alternative is to program by hand.
BTW, what scanner model do you have? This will determine the software package to be recommended.
