Buying advice plz
You can try the AOR-ARD25 works with many AOR scanners,but at
$560.00 cdn,might be better off with a 396xt that can
do trunking. Also the AOR-ARD25 is just an add-on for APCO
Project 25. The 396xt has everything you need.
Note:
"Some words of caution - The ARD25 is not effective on systems
that use encryption or digital modulation other than APCO
Project 25. It cannot translate signals from receivers that
do not have a 10.7 MHz IF output, as the full channel
bandwidth is needed to convert the signal from digital to
analog. The ARD25 does not add trunking capabilities to
your receiver. Some jurisdictions may limit the use of devices
such as the ARD25"
