| General Scanning Forum General forum for the discussion of radio communications related information, including discussion regarding scanners and radio receivers. Location specific posts should be directed to the regional forums listed below. |
10-25-2009, 07:50 PM
Why use so many scanners?
I have noticed in pictures that a lot of folks have lots and lots of scanners going. Like six of the exact same model.
Why?
M
10-25-2009, 07:54 PM
Wirelessly posted (MOT-QA30/00.72 UP.Browser/7.2.7.5.610 (GUI) MMP/2.0)
Because say you have cities 1, 2, 3, 4, 5, 6. And we will say 4, 5, 6 are on a digital system. These people want to be able to monitor say FD and PD of these cities all at the same time. You can monitor more things simultaneously if you have multiple scanners.
_/\_"Smart" is understanding how ignorant you really are_/\_
Psalm 23:4 "Even though I walk through the Valley of the Shadow of Death, I will fear no evil, for You are with me...."
10-25-2009, 08:00 PM
Why?
M
NEED...MORE...SCANNERS!  Must have....more!
N9ZAS
10-25-2009, 08:33 PM
I can only keep track of what is going on just with one scanner.
my head would explode if I tried to listen to all mine and I have
1,000 if you do not count the trunk system.
10-25-2009, 08:38 PM
I separate all 8 speakers,and equalize volume levels. It makes it much easier!
N9ZAS
10-25-2009, 08:44 PM
Why?
M
N9ZAS
I'm with you on this. It made me laugh.
You get used to just listening for specific keywords, there's no need to listen to every license plate being cleared. That's how they run multiple scanners, they aren't listening to every word.
10-25-2009, 08:56 PM
I mostly run multiple scanners simultaneously because of the way trunking works. With only conventional channels, when the scanner gets to an active channel it will stop even in the middle of a conversation. But in the case of trunking, data is typically only sent for a channel once. If the scanner is monitoring something other than the control channel when that data is sent, it will not know where the conversation is and you miss it.
Another issue is the specific frequencies being used. Trunked systems in my area (that I want to monitor) are on the 800 MHz band. Most other stuff I want to monitor is VHF. So by dedicating a scanner for trunking, it can also have a dedicated 800 MHz antenna. It makes for better reception, and more reception, especially from the local TRSs.
PRO-95 | (customized) PRO-10 | PRO-97 | PRO-77 (customized) | PRO-92 | PSR-300
10-25-2009, 09:00 PM
It's easy for me because because I only have 2 -4 talkgroups for this area!
N9ZAS
10-25-2009, 09:05 PM
Why?
M
In some case, two, maybe even three make sense. Mostly the reasons already given ie. dedicated antennas for certain bands, conventional vs. trunking, ect. Once you get over three, it just starts to get a little crazy.
I am NOT labeling a group, but I also think there are people on here that like to show off. As though they have entered into some higher place in life because they own 4+ $500 scanners and stack them nice and neat.
Don't take the above statement as jealousy. I am far from that. I own plenty of scanners and amateur equipment myself to go around, but just because I do, it doesn't mean I am better than anyone else.
When it comes down to it in REAL life, who cares?
Just my $0.02
10-25-2009, 09:15 PM
Why?
M
Let's put it this way, it's like being married and having five other women 'on the side'.
Why not?
10-25-2009, 09:33 PM
And they talk, and talk, and talk, and we shut up and listen.
10-25-2009, 09:35 PM
I won't talk about anyone else, so I'll just talk about my own experience.
I have 3 digital scanners, working on the 4th. The reason I have more than one scanner are many. Here's a few of the main reasons.
1. Listening to different systems quicker (one scanner scrolling through 250-500 channels means I can miss a lot)
2. When a major event happens, there might be multiple channels in use at the same time for the same event. My Uniden 296 & 396T's only allow me to listen to one TG at one time.
3. I am able to loan a scanner to a friend that might want to get into the hobby, without cutting myself out of being able to listen.
4. So I can provide a scanner feed to RR.com
MM
10-25-2009, 09:44 PM
As you get used to it and more into it, you will know ;-)
I'm sitting here with an HF rig, a VHF/UHF rig, music playing and a scanner going all at once, through a Roland 10ch compact mixer and listening in headphones. I'd have another scanner too, but I dedicated that one to RR feeds ;-).
Roland U.S. - M-10MX: 10-Channel Battery-Powered Mixer
This is the best piece of gear I've added in a long time. Mixes all my radios down to a pair of Bose Mediamate speakers. Decent isolation on all the inputs as it is tossed just a few feet from a kW HF amp and other transmitters and have no trouble with it.
http://www.kc2rgw.com/
Various info on SDR, ham radio, monitoring, and rantings of a lunatic.
10-25-2009, 10:21 PM
Originally Posted by kc2rgw
...through a Roland 10ch compact mixer and listening in headphones...
That is not a bad idea. Easy to get your levels right.
As a guitar player, I love mixers.
10-25-2009, 10:29 PM
all I know is I have trouble listening to one and trying to read the board. I always
end up turning the volume down tell I'm done reading.
10-25-2009, 10:37 PM
its like a addiction. we all are scanneraholics..
10-25-2009, 11:03 PM
Agreed, but there is a sane limit
10-25-2009, 11:19 PM
Because only one fits in my pocket protector?
Because I have a McDonald's and Wendy's just down the street, and I have to hear both drive-thru's?
10-26-2009, 01:55 AM
Then there's us "staticaddicts"!
N9ZAS
10-26-2009, 02:03 AM
Originally Posted by gmclam
IBut in the case of trunking, data is typically only sent for a channel once. If the scanner is monitoring something other than the control channel when that data is sent, it will not know where the conversation is and you miss it.
That is completely false. You might want to look into late entry.
