Apologies if this has been discussed before, but the search function is inoperative at the moment.
I was planning to put a mobile scanner in my vehicle, which also contains a VHF/UHF dual bander and an HF radio. In discussing this with another ham, he mentioned that he once had a mobile scanner as well. Seems that all was good until one day when he turned the mobile VHF radio to full power (40 watts, IIRC) and it blew the frontend on the Radio Shack scanner (model unknown.)
Antennas were approximately 5' apart (this was on a Suburban), the VHF close to the front and the scanner antenna toward the rear.
Is this a common problem? Can it be avoided in any way, or do wideband scanners and powerful transceivers just not play well together? Are some brands/models more robust than others?
