xoclipse
Hey everyone, I'm new to the forums, just got myself a PRO-97 scanner from Radio Shack, and have been loving every minute of playing with it.
While I was messing with the signal stalker feature, I put my garage door opener close to it to see if it the scanner could pick it up. I found out the garage door opener transmits at 390.00Mhz, and tuned my scanner accordingly. When I pressed the button on the garage door, I could hear the little data bursts through the scanners speakers.
This gave me the idea of writing a program to decode these little "data bursts", to find out the actual code the opener sends. I have an older garage door, before rolling codes came around. My opener has 12 dip switches in the back of it, which match up to the actual garage door mechanism in the garage. I figure I should be able to decode the signal the opener sends to retreive the values of each dip switch.
I hooked up the headphone output to my computer, and did a little analysis of the waveform, and I'm pretty sure it uses ASK(amplitude shift keying). Soon I'm going to add the discriminator output to the scanner so I can get a little more precise of a waveform.
So right now I'm working on writing a C++ program using Microsoft's Multimedia API to get the input from the scanner and see if I can decode it and display the code the garage opener sends. If anyone is interested in helping me, or has any resources for programming this kind of application, please let me know.
Chris
Chris
